Cutting matching tapers
Home Forums Beginners questions Cutting matching tapers
  • #749280
    Paul McDonough
      @paulmcdonough43628
      I have the need to cut matching tapers, one male one in brass that sits on the drive shaft of my engine 1/4″ dia and the other matching female taper has to be cut in a mild steel flywheel.
      Because the tapers are quite small, the ‘cone’ of the male part is a slither over 1/4″ at one end and no more than 9mm diameter at the other. The height/length of the cone is no more than 8mm.
      My issue is that I am struggling to cut the female taper without the line of the ‘slant height’ curving.
      The boring tool, which I have cut from 5mm x 5mm HSS is by necessity quite thin to reach into the bore of the taper and I suspect it is deflecting, despite my very light cuts.
      Is there a better way please? Even if this involves buying a purpose made tool, as the need to cut these tapers seems to reoccur a fair bit!
      Many thanks P.McD
      Andrew Johnston
        @andrewjohnston13878
        Can we assume that the tapers are being cut with the topslide set over and that the topslide is not moved between internal and external tapers?
        The HSS tool shouldn’t be deflecting that much. How is the tool ground and what are the cutting parameters?
        For boring, and screwcutting, in small diameter holes I have used these tools:
        Tiny Tools
        #749308
        Clive Foster
          @clivefoster55965
          Start with a conical blank for your boring tool rather than a round or square one.
          Only the tip needs to get into the small end so the size of the shank further down is defined by what will fit in the tapered bore. Starting by step drilling would make a bit more room too.
          I know nothing about them but there are “D-bit” style reamers. Relatively easy to make and possibly up to converting a step drilled hole into a taper.
          #749317
          Clive Brown 1
            @clivebrown1
            For a taper of that size, as said above, a  D-bit is much the best way to go IMO. Machine the male taper on the shaft by setting over the lathe top-slide. Machine the D-bit taper at the same setting on a suitable piece of silver steel. Mill or file that taper to half diameter + 1 – 2 “thou”. Harden and temper. Stone the flat to give a cutting edge.
            #749337
              I suspect lack of clearance is pushing the cutting edge off the surface rather than the tool deflecting under load
              One way to get better access is to cut the female taper with the big end facing out and with the topslide still set at the same angle run the lathe in reverse and cut on the back side to do the male taper, if you need to use tailstock support on the crankshaft then just mount it with the small end of the taper facing the headstock.
              20190818_112042
              A milling cutter also makes a good boring bar when you get down to these sizes, hold it in the toolpost with one flute on ctr height. Not quite parallel to the angle of the topslide so the side does not rub Not a flywheel but a similar size taper being cut for a venturi. 5mm dia cutter will work for your 6mm min hole. At 5mm it will be stiffer than most small boring bars
              DSC01305
              DSC01306
              This one was cut with the tool cutting on the far side, Crankshaft taper being used to test fit the distance it goes in upto the red line.
              20210509_082516
              #749338
              bernard towers
                @bernardtowers37738
                Definitely D bit territory at that size.
                #749341
                DC31k
                  @dc31k
                  Would it be possible to cut two matching male tapers?
                  Then one can be sacrificed to lap the female one to a better fit after boring as best you can by other means.
                  That avoids the need for heat treating a D-bit.
                  #749405
                  bernard towers
                    @bernardtowers37738
                    If you go the D bit route the tapers will match no need for lapping and heat treating a small D bit is something we should all be able to do with some degree of success, enough to work once anyway.
                    #749414
                    Andrew Johnston
                      The tapered valves and the D-bit used to make the tapered, blind and flat bottomed holes are show along the bottom of this picture:
                      Check_Valve_Parts
                      The valves and D-bit were machined at one setting on the lathe, although to get the best surface finish they were then ground on the cylindrical grinder. The tapered seat was stepped drilled before using the D-bit to form the taper. Internals shown here:
                      Tapered Seats
