Sparey Diesel Crankshaft
Home Forums I/C Engines Sparey Diesel Crankshaft
  • #747359
    Clive Brown 1
      @clivebrown1
      I’m making the 5cc Sparey Diesel to Hemingway’s plans. The crankshaft is specified as from 1.25″ dia steel bar. In particular, the overhung crank-pin looks to be an awkward machining operation. I’m wondering if a press-fit or loctite assembly might be OK. Perhaps also even for the crank web onto the shaft itself.
      Any thoughts or experience of such construction?
      crankshaft
        machining is not too hard, you can either use  a keats type angle plate or bore  a block of aluminium to clamp the shaft in then the block can be held in the 4 Jaw. If going for an integral pin then you can mill a lot of the waste away to leave a small square that can be easily turned and a clean up facing cut to the web.
        HPIM1458
        IMAG0684
        IMAG0694
        I have also done pressed in silver steel pins, a hand reamer not run all the way through will leave a taper that grips the pin more the further it is pressed in.
        #747363
        Clive Brown 1
          @clivebrown1
          Thanks for such a quick response JasonB. How do you manage such relevant pictures at a moments notice? My Keats angle plate is a fairly big thing and doesn’t really appeal for this job. The aluminium block looks better to me, but the shaft will need tight clamping. i think that might be the way to go though.
          #747369
          bernard towers
            @bernardtowers37738
            When I made mine as all my others I do them all in one as it is imperative that the pin is perfectly in line with the crankIMG_7937
            #747375
            larry phelan 1
              @larryphelan1
              Clive,
              You wonder how Jason manages to respond so quickly ?
              I suspect he must have done these things before !!
              #747379
                Jason beat me to it.
                It’s so easy to do it with the offset clamp, even I managed to do it!
                Unfortunately, it’s still 50% unfinished since this photo taken in 2003. Oh heck, that’s 21 years ago…
                Raw Materials
                #747393
                  That photo looks 100% unfinished too me😊
                Home Forums I/C Engines Topics
