Greenly Under Type Compound Engine
Home Forums The Tea Room Greenly Under Type Compound Engine
  • #743337
    Harry Wilkes
      @harrywilkes58467
      I have seen a engine which I’m interested in however the pump is missing, the engine in question is a Henry Greenly compound under type 1.5 inch scale from what info I’ve found are that details of the construction and drawings can be found in Greenly’s articles, published in volumes 8 to 11 of “Model Engineer” magazine, 1903-4. By any chance any members would have these volumes are any details of it’s pump
      H
        Looks like you should find a friendly correspondent in the USA, Harry:
        https://onlinebooks.library.upenn.edu/webbin/serial?id=modelengelec
          The H A Taylor updated one was featured in the 70s so you may have a bit more luck with those articles.
          Maxitrak list the drawings as part of the Greenly archive
          Couple of members seem to have them, may be worth a PM. See this thread.
          #743378
          Bob Worsley
            @bobworsley31976
            The HA Taylor update isn’t exactly the same, but the drawings are available from Sarik. The original boiler was rivetted and soft soldered, would need the new drawing to update this as a minimum.
            I have the first volume, 1906 I thought, with the A3 sized drawing plus a few other piece parts, nothing that isn’t available from the Taylor version.
