I’m not sure why you want to bronze braze as opposed to silver braze. Can you explain?
Silver brazing/soldering is adequate for delicate components. All my silver jewellery work was done with silver solder of various temperature grades: hard, medium, easy, and extra easy. For non-hallmarking silver soldering I generally use Johnson Matthey Silverflo 55 solder with Easy Flo 2 flux powder mixed into a paste. On bigger work I also feed with rods, as Jason suggests. Dipping a heated rod into dry flux powder (at the right temp. the powder will stick to the rod) means you don’t need to apply flux paste to the joint at all.
I reserve bronze brazing for repairing or joining steel components subject to heavy usage, though these are not necessarily big components. I use two different kinds of bronze rod: silicon bronze rods and manganese bronze rods. The first has better gap filling characteristics, the latter better flow characteristics.
For bronze brazing I generally use Sif Bronze flux powder, though I’ve also used Easy Flo 2 successfully.
BTW, the flux paste mix shown in the video is too watery for most purposes, even after the demonstrator has added several dollops of extra powder.
