Seivert Regulators
Seivert Regulators
Home Forums General Questions Seivert Regulators
  • #736716
    ron vale 3
      @ronvale3
      I have a dual outlet sievert regulator the model number is 3045..so old it is no longer listed!!
      It has developed a leak between the connection tube that screws into the Propane bottle and the larger diameter body that has the  sticker on it ( hope that helps) although the pic is 3.4mb jpg it will not load
      I have rung the UK distributors and they cannot assist, but does anyone on here know of a firm that might look at it and repair it?
      noel shelley
        @noelshelley55608
        It is unlikely you will find a company to do this task, health and safety Etc. Good luck. Noel
        #736763
        Vic
          @vic
          I found a picture online in case it helps the discussion.
          IMG_0865
          #736769
          DC31k
            @dc31k
            The connection tube should just screw into the regulator body.
            Often there is a broached hexagon inside the part that directly touches the bottle that allows that tube to unscrew (that is the part that is changed when the regulator is sold in a different country with a different propane bottle interface).
            The challenge is that the screwed joint may be loctited. The fact that it is leaking might mean the loctite has failed with age, which also increases your chance of unscrewing it.
            At the least, it is worth trying to unscrew it, clean everything and reassemble with a thread sealant (e.g. Screwfix 4373J).
            If your propane hose looks anything like the one in the photo, a replacement hose would be a good idea.
            #736773
            JohnF
              @johnf59703
              If you cannot fined a reputable expert repair shop personally I would purchase a new one, there seems to be plenty for under £20.  Also consider the cost of repair, shipping etc its a no brainer !
              Also when one considers the possible outcome of dodgy gas equipment ????
              Cheers John
              #736777
              Clive Brown 1
                @clivebrown1
                Regulators normally have their date of manufacture stamped on them. The recommended life-span is 5 years, this does seemsa bit short, but would be a requirement for, say, boat gas safety inspections AFAIK.
                The condition of the hoses in the picture above is appalling.
                #736781
                Vic
                  @vic
                  I think it may be five years because few people change hoses and that’s likely the limiting factor.  It seems cheaper in some cases to buy a new regulator with hose than buy replacement hoses and clips.
                  Yes, those hoses on that eBay offering were bad. I wonder if the buyer replaced them?!
                  The last couple of regulators I bought were very cheap.
                  #736785
                  bernard towers
                    @bernardtowers37738
                    I doubt if you would get an adjustable reg of that quality for £20!
                    #736787
                    DC31k
                      @dc31k
                      Please link to one of the “plenty”.
                      It will need to be:
                      a) adjustable;
                      b) twin outlet;
                      c) under £20 to my doorstep.
                      #736796
                      JohnF
                        @johnf59703
                        It will need to be:
                        a) adjustable;
                        b) twin outlet;
                        Ah! missed the dual outlet and it does seems these are few and far between.  Single outlet adjustable units are available from under £20 and even the “better” brands are in the £30-£50 range but I cannot see any with dual outlets ?
                        #736850
                        shaun meakin 1
                          @shaunmeakin1
                          We supply a single outlet variable regulator at https://cupalloys.co.uk/product/adjustable-propane-regulator/
                          As for a double all we could offer would be a doubkle neck tube https://www.sievert.se/products/necktubes/double-neck-tube/ please call if of interest.
                          Shaun.
                          #736871
                          Vic
                            @vic
                            I paid under a tenner for the regulator for my Pizza Oven and it hasn’t complained about the quality! 🤣
                            For more exotic stuff I’ve used Hamilton Gas Products.
                            https://www.gasproducts.co.uk
                            #736874
                            Vic
                              @vic
                              Would a double outlet be any good?
                              IMG_0890
