Relative Humidity Sensor
Home Forums General Questions Relative Humidity Sensor
  • #733945
    Colin Whittaker
      @colinwhittaker20544
      I’m dreaming of a wall mounted gauge with a mechanical dial showing the relative humidity.
      According to Google “Natural Gut” is sensitive to humidity and has been used for basic humidity sensors. So I bought some natural gut from eBay, hung it from the ceiling of my workshop with a 1kg weight at the end of 2.4m of gut and measured the change in length as the humidity changed from 80% to 50%.
      There’s maybe a 1cm change in length as the humidity and temperature changes but not in any repeatable way and I could easily be observing thermal expansion instead of any humidity sensitivity.
      As I write this I’m beginning to wonder if my gut’s been sealed in some way. So my next step is to apply some acetone and repeat the tests.
      Against the probability of seeing the same results … does anyone know how to build a non electronic relative humidity sensor?
      Thanks,     Colin
        Hygrometers (humidity meters) are sensitive instruments. I am old enough to have worked on air con systems that used horsehair hygrometers and humidistats to monitor and control humidity. Human hair is said to work better.  If you google “hair hygrometer” you may find more info on making your own.
        As said, sensitive instruments. So hanging a a 1kg weight on your gut is probably stretching it and doing all kinds of weird stuff to it. Try it with shorter length of gut and minimal weight on it. Attach the gut, or hair, to some kind of lightweight pointer that is pivoted close to the attachment point for the gut/hair, so a small amount of movement of the gut/hair is magnified by the leverage of the long end of the pointer. You might need a small spring or weight just enough to keep tension on the gut/hair but not stretch it or stop it contracting.
        #733951
        Anonymous
          Wheatstone bridge with the active element being fibre glass impregnated with lithium chloride.
          #733954
          duncan webster 1
            @duncanwebster1
            Seaweed!
            #733959
            Martin Kyte
              @martinkyte99762
              Hair in combination with unsurprisingly a hair spring to make a torsion indicator.
              regards Martin
              #734003
              Alan Charleston
                @alancharleston78882
                Hi,
                Back in the 1970s I used to sometimes record the readings from various instruments in a climatological weather station in New Zealand. One of the instruments was a recording humidity meter. The sensor part of it was a bundle of horsehair about 6″ long. It may have comprised perhaps a dozen individual hairs. I’m not sure if the instrument measured a length change with humidity or if the bundle was twisted and changes in torsion were measured. Each day, the horsehair was cleaned using a small paintbrush and distilled water. Apart from removing any salt from the horsehair which could have affected its reaction to humidity, it also checked the zero of the instrument which read 100%r.h. once a day when it was cleaned.
                Recording clockwork thermohygrographs turn up on the local auction site fairly regularly and don’t fetch all that much ($200 – $300).
                Wall mounted analog hygrometers are also readily available.
                Alan C.
                #734005
                Alan Charleston
                  Hi Again,
                  If you are after a non-electronic humidity meter, the obvious answer is a wet and dry bulb thermometer set up.
                  Alan C.
                  #734016
                  Howi
                    @howi
                    I have a gut feeling this is going know where!
                    #734052
                    gerry madden
                      @gerrymadden53711
                      Interesting thread. Many years ago I bought a bunch of very dilapidated hygrometers from an Aero-jumble. I was attracted by the nice ceramic dials which bore the respected name Negretti and Zambra. These turned out to be hair hygrometers but it was very fine, not horse. Much of it had broken and I needed some more.
                      I read somewhere that the best/finest hair was from blond ladies. Since I was working for a Danish company at the time I decided that was probably the best place to try to procure some suitable material.
                      On my next trip over to Denmark I had a meeting with our buyer whom I had known for some time. During the meeting it occurred to me that her ‘barnet’ was of a appropriate length and diameter specification so afterwards I explained to her the technical background of my private project and my very modest needs. I don’t recall her saying anything, but her expression said it all. The matter was never raised again with her or anyone else and sadly two of my three hygrometers remains unfinished.
                      Gerry
                      #734056
                      Peter Cook 6
                        @petercook6
                        They do exist, and must be fairly simple. My wife has a clock (like this one) in her Summerhouse/workshop with a subsidiary humidity dial. The battery only drives a standard quartz movement so the humidity ( and temperature) sub dial(s) are mechanical. Amazon do (at 2 for £10!) a non-battery thermometer/hygrometer using presumably similar mechanisms.
                        I wouldn’t be thanked for disassembling my wife’s clock, but at Amazon’s price I could be tempted to buy one and investigate how it worked.
                        PS this patent might be of interest.
                        #734059
                          This won’t do much to inform the discussion, but I will just mention it:
                          Having worked for eleven years [mid 1970s through mid 1980s] in an environmental test-house, I recall that the accurate measurement of relative humidity was one of our biggest challenges … By any normal standards, these contraptions all have remarkably wide tolerances.
                          Edit: __ Couldn’t find this on the NPL site … Grrr!!
                          Bedtime reading:
                          https://www.rotronic.com/media/productattachments/files/n/p/npl_guide_to_humidity.pdf
                          IMG_9709
                          #734153
                            Can’t find the book it’s in, not ‘The Amateur Scientist’, but from memory this arrangement should work after a fashion:
                            relhum
                            A drinking straw is pinned to a vertical board by a pin.  The straw is held away from the vertical surface by a glass bead (Ladies have thousands of ’em).
                            The weight of the roughly horizontal straw is supported by a human hair, about 150mm long, the far end connected to the fixed pin.
                            As the length of the hair varies with humidity, the movement at the pointer-end of the straw is amplified by the lever action about the axle pin.
                            Longer the hair the better, but the biggest improvement would be to make a proper lightweight gear amplifier – a clock-making job.  I vaguely remember it being recommended to slice off the pointer end of the straw to reduce weight.
                            By far the easiest way to measure Relative Humidity with an electronic sensor.   RH depends on temperature and pressure, so these have to be measured first.   The BME280 does both, and does most of the necessary maths.  The main correction needed outside the sensor is your local air-pressure at sea-level, which varies with the weather.  Accuracy about 4 times better than a good hair instrument.
                            Arduino instructions here.
                            V8Eng
                              @v8eng
                              #734165
                              duncan webster 1
                                @duncanwebster1
                                relhum
                                Negative gravity in Somerset?
                                #734191
                                Alan Charleston
                                  Hi Again,
                                  This site gives a schematic for a hair hygrometer.
                                  What is Hair Hygrometer? Working, Diagram, & Applications
                                  Alan C.
                                  #736419
                                  Colin Whittaker
                                    Thank you all for your ideas. I have some AliExpress Horse Hair on order to try some of the ideas supplied. The electronic approaches I’m against because I know too much about electronics and something mechanical feels more magical.
                                    I have already had some success using wood glued together in a bimetallic strip type approach. One piece is end grain which readily adsorbs moisture from the air and preferentially shortens or lengthens while the other has the grain along the piece and less readily absorbs moisture and then only changes its thickness.  Screenshot 2024-06-16 201431
                                    The glue is two part quick drying epoxy that does not readily penetrate either wood strip.
                                    With a 60 cm long strip that has a 4-5 mm glued thickness and which is clamped at one end I can see almost 10 cm of deflection with a change in humidity from 40% to 80% as the upper layer expands. It looks like there is a time constant measured in 10s of minutes.
                                    Long term changes in the humidity level of the lower strip will have marginal effects on its length but in any case I plan to varnish all faces except the top to slow or eliminate moisture level changes.
                                    I still have a sub mm thick end grain strip that I plan to test as well. I suspect it will have a more rapid response (as long as it’s paired with a similar thickness longitudinal base strip.
                                    Now, how can I make something prettier than this, https://www.instructables.com/Humidity-Gauge-Made-Out-of-Wood/ ?
                                    #736473
                                      Wow. Well done.
                                      No wonder my wooden doors jam in their frames in the monsoon rainy season here in the tropics when humidity sits over 90 percent for months.
                                      As an aside, an old sailor once told me relative humidity was the sweat that came off your, ummm… brow, when having relations with your sister. But I have never verified that.
                                      #736513
                                        relhum
                                        If only!   Classic example of why memory is untrustworthy.  Looks like I remembered the principle, but somehow inverted gravity,  Down here in Zummerzet we blame the Scrumpy.    If you can remember the night before you didn’t have any!
