The circuit diagram fits well with the pictures of the parts. Though a simple circuit, just about any of the components could be faulty, but most may be able be checked to a reasonable extent with a multi meter. Unfortunately, the module probably contains the electronic items, which spoils things a little but it could be much worse.
Check both coils are continuous, excitor a few ohms, and the trigger likely tens of ohms (but neither zero ohms). Being subject to direct vibration and heat, a fault here is quite likely, with a broken connection quite possible.
If there is a diode test on the meter, a diode should conduct one way only, not conduct the other (and not be short circuit), and the SCR would show up as two diodes provided you understood it sufficiently. The capacitor should not test as continuous, but will look like that when the probes are first applied as it charges up. It will behave the same again if the probe connections are reversed, but if left connected to the meter long enough, it should end up a high resistance.
Good luck.
