Well I never! In a lifetime of messing with potentiometers I’ve never come across one where the switch closed in the off position. Yet here it is, a real live Unicorn!
It was a first for me too. 🙂
For posterity (since I’ve just found the info), a better quality pot for the ‘closed when off’ option is a Bourns model 56 Series which can be obtained with an SPDT switch.
Part numbers:
5k ohm (or 4.7k) Bourns 56AAD-C28-B13/R81L
10k ohm: Bourns 56AAD-C28-B15/R81L
I couldn’t find a UK supplier for single quantities of the B13 (5k) pot, so went with the B15 (10k) pot as I was pretty sure it would still work. (It does).
The 10k pot is available from RS Components it was about £12 four years ago, but I now see it’s £24!!
https://uk.rs-online.com/web/p/potentiometers/7422198/
Mouser seem to carry it too, but also pricey:
https://www.mouser.co.uk/ProductDetail/Bourns/56AAD-C28-B15-R81L?qs=QpZVHcK7GhTE0BqrfbGLYA%3D%3D
Other variants to look out for:
5th character ‘A’ OK (anti rotation lug)
7th character ‘B’ OK (smaller shaft diameter)
8th/9th characters 24 OK (shorter shaft)
11th character ‘E’ OK (electrical tolerance)
It is a much, much better quality component.
Old and new:
NB! This may or may not be relevant to the Chester conquest mill.
