It’s not a bodge, but why would you want to do it?
There are four possibilities:
External parallel to internal parallel: Common; not self sealing, will need tape or paste to get a seal
External parallel to internal taper: Not common; may be self sealing or may not
External taper to internal parallel: Fairly common; should be self sealing
External taper to internal taper: Common; is self sealing
