Toolmakers clamps
Toolmakers clamps
Home Forums General Questions Toolmakers clamps
Viewing 25 posts - 1 through 25 (of 26 total)
  • #712772
    Bill Dawes
      @billdawes
      When I took up ME some 12 years ago I enthusiastically equipped myself with various tools via birthday, christmas, fathers day presents etc.
      One of the things was some toolmakers clamps, I think I have used them once, for what I can’t remember.
      Please, someone tell me I have been missing out on a whole world of useful workholding.
      Bill D.
        If you never use them for anything else, Bill … they make superb ‘adjustable spanners’
        Bill Dawes
          @billdawes
          I should add that I have been and enthusiastic collector of all sorts of DIY tools for many decades, the usual drills, saws, hammers, screwdrivers etc of all shapes and sizes of course and used frequently. I also have many obscure hand and power tools that I use rarely but are an absolute blessing when I do need them.
          I have beem married for over 40 years and in the early days my wife could never understand why I need more than one screwdriver for instance, over the years she has appreciated why, having helped out on various occasions with projects.
          When I started ME I had great plans to make all sorts of jigs and clever little fixtures to help with my model making but quickly realised I would be spending more time on making the tools to make models and never having the time to make models!
          My current project, 5″ gauge Emily Victoria featured in ME magazine, some 12 years on and I am seeing light at the end of the tunnel, all the valve gear now fitted ready for a test on compressed air hopefully.
          Boiler, saddle tank and cab made. Done my own hyrostatic test on boiler but plucking up courage to take it down to Geoff at Weston Steam close to where I live for certification, I say plucking up courage as my effort is a bit scruffy looking compared Weston steams Helen’s masterpieces. As my various posts in the pasts I have more than once been ready to consign it to the scrap bin, still time for that I suppose, don’t know if it will work yet.
          Bill D.
          #712787
          David George 1
            @davidgeorge1
            As a retired toolmaker I have three diferent sizes of toolmakers clamps. They are invaluable holding parts to angle plates, Clamping flat plates for drilling and other holding jobs.
            20190327_122748
            David
            #712789
              I use my various ones quite a bit from the crusty ones that get used to hold things while silver soldering to the cleaner that hold fabrications together as the parts are assembled prior to joining or holding small part to angle plates etc when machining.
              #712798
              Nick Clarke 3
                @nickclarke3
                In my case I have several because they are ideal for holding things together while waiting for a more permanent joint to be made.
                The reason I have several is because there are several such assemblies lying on my bench waiting for the permanent joining and so every so often I run out and have to buy more!
                #712804
                Andrew Tinsley
                  @andrewtinsley63637
                  I must have at least a couple of dozen of various sizes. I use them all the time for the sort of jobs that have been described above. I don’t know how the OP has survived so long without using them on a regular basis! As far as I am concerned you can’t have enough of them.
                  Andrew.
                  #712814
                  Paul Rhodes
                    @paulrhodes20292
                    I have only ever used mine to loosely hold small pieces for drilling, It enables the drill to “self find” the punch mark.
                    With my skill set ,this is as close as I will ever get to a toolmaker!
                    #712820
                    Mick B1
                      @mickb1
                      I’ve got one pair that I’ve used maybe 4 or 5 times. Most recently I needed to drill clean holes of a specific size in thin spring steel. I used the clamps to hold the spring steel between two 1mm thick mild steel strips. It worked very nicely.
                      For the sort of stuff I do, I’ve found you don’t need them often, but when you do there aren’t many other options.
                      #712833
                      noel shelley
                        @noelshelley55608
                        The various comments give some clues as to the apprenticed men and the rest ! As an apprentice you had to make your own by hand and by the time you had you would find lots of jobs for them ! Noel, the apprentice !
                        #712836
                        old mart
                          @oldmart
                          I have three different sizes and the museum was given a box with about four in it. I rarely use them as they are not very strong and cannot hold securely. I have never been a fan of them.
                          #712869
                          John Purdy
                            @johnpurdy78347
                            I’m with Andrew, I have close to 20, from 1″ to 6″ and I don’t know how I would get along without them. They get used all the time for clamping for drilling, or to angle plates, extra security while milling some jobs, holding items on the surface plate for marking out or measuring. I find the uses are endless.
                            JohnClamps
                            #712883
                              No apprenticeship for me and I’m not an engineer let alone a tool maker but I did make a pair at school that still get used though they are one of the crusty ones now
                              #712890
                              Martin Connelly
                                @martinconnelly55370
                                One of my uses is as a vice stop because, since I have some, I don’t need to make a vice stop. They grip nicely on the top edge of a milling vice.
                                Martin C
                                #712894
                                  No matter how rarely they are used, without them, there will be jobs which are extremely difficult or even impossible.
                                  Very useful, if only to hold pieces against an angle plate whilst measured or marked out.
                                  #712902
                                  Bill Phinn
                                    @billphinn90025
                                    I most often use mine to hold small square or rectangular pieces in my bandsaw’s vice – pieces that are too short to hold in the vice itself. This actually seems to be more common with me than cutting something long enough to go in the vice.  It’s easy to get the piece you want to cut reasonably square if you use the jaws of the clamp as reference surfaces when loading the piece into the clamp and if you add a second “foot” (like in the picture*) with the same projection as the captive thumbscrew on the fixed jaw.
                                    Very small round pieces sometimes also get held in toolmaker’s clamps for cutting in the bandsaw, but if they are long enough to be held safely in an ER collet I put them in either an ER20 or ER32 straight-shanked collet chuck with a flatted side held in the vice.
                                    *Ah well, the forum won’t let me upload it, even though it is a valid jpg file and only 383 KB.
                                    #713660
                                    Bill Dawes
                                      @billdawes
                                      Thanks for replies guys. Despite the fact that I did do an engineering apprenticship and five years on the shop floor my other 60 odd years working have been largely office based on technical sales and engineering dept. so not had a lifetime on the shop floor. That’s no excuse of course for not using tools correctly and I know there are many model engineers with no engineering experience at all but turn out beautifully made pieces of scale engineering.
                                      I must try to use my clamps more, like everyone I do frequently need a clamp of some description which is usually mole grips, G clamps and the like. I have a large range of G clamps which I find invaluable.
                                      Thanks again.
                                      Bill D.
                                      #713689
                                      Chris Crew
                                        @chriscrew66644
                                        “I must try to use my clamps more, like everyone I do frequently need a clamp of some description which is usually mole grips, G clamps and the like. I have a large range of G clamps which I find invaluable.”
                                        I agree with you Bill. I find G-clamps much more convenient and less ‘fiddly’ than toolmakers clamps. They provide a more reliable hold too, IMO. I am not a time-served man either, although I did once have a craft apprenticeship with BREL in Doncaster which I was young and stupid enough to abandon before completion. A decision I have regretted for the rest of my life but at least it gave me the basic turning and fitting skills.
                                        #713836
                                        John Purdy
                                          @johnpurdy78347
                                          Bill
                                          Here’s a use of toolmakers clamps to securely hold two awkward shaped pieces in the correct registration for spotting through tapping holes into the lower piece. As an added bonus the square parallel lower jaw makes a convenient way to hold the assembly square in the drill press vice. If you first clamp the lower jaw in the vice slightly proud of the jaws, then positioning the two pieces correctly and clamping them is easy as the vice acts as a third hand. Once clamped in position the vice can be loosened and the whole assembly can be dropped down so the lower piece is sitting squarely on the vice jaw tops.
                                          Clamp
                                          #713848
                                            A lot will depend on what type of work you do, I also use G-clamps but for larger items as they would be far too bulky to try and holed say a strip of 1/8″ half round beading to the edge of a tender but fine to hold a bit of 50mm sq section or a big casting to an angle plate.
                                            Same with moles, ok on a bit of black bar but I would not want to use them to hold a finished aluminium part due to marking the surface and if you introduce packing to protect the part then they become more fiddly.
                                            #713851
                                              Other advantage of toolmakers clamps over G-clamps is that they are relatively flat at the business end and won’t get in the way of a chuck.
                                              They can also grip right on their ends where as a G clap needs most of its end on teh work surface particularly the swivel end.
                                              Good example of both here holding this 50mm long casting so that the 4 holes in the feet can be drilled. G-clamps would stick up and hinder the chuck and also need to overlap the par a lot more.
                                              20230501_144726
                                              #714187
                                              Joseph Skonieczny
                                                @josephskonieczny88685
                                                Personally, in my opinion, I was never a fan of the clamps. No offence to the devotees, I prefer (drum roll) Kant Twist clamps. I got used to them during my apprenticeship in the machine repair trades. A toolmaker in the department showed me his toolmakers clamps he had made during his apprenticeship. I was totally blown away and completely underwhelmed by their appearance and grip strength. Needless to say, he really did not appreciate my opinion. I’ve been retired now for the last 11 years after 39 years in the trade. I still don’t own any of the clamps and my life has been pleasant without them. Thank you very much!
                                                #714200
                                                bernard towers
                                                  @bernardtowers37738
                                                  I have both but you would have a problem getting a Kant clamp in small space where a 1 1/2″ toolmakers goes in easily.
                                                  #714236
                                                  Bill Phinn
                                                    @billphinn90025
                                                    There’s a multitude of differences between the designs and potential applications of toolmaker’s clamps on the one hand and Kant-Twist clamps on the other. The primary one, for my purposes, is that Kant-Twist clamps are not amenable to being clamped in machine vices, whereas toolmaker’s clamps are.
                                                    #714279
                                                    Vic
                                                      @vic
                                                      I agree, sadly they are expensive to buy in the UK.
