G'day.
Got on with extending a drill to make my long hole.
Found a nice pre-loved 8mm printer rod, it turned nicely with a freshly honed bit.
Very pleased with the mini-lathe accuracy, I pinched the M3 ER 25 collet chuck from my X2 mill to hold the 8mm rod. 0.210" at both ends of the rod using a travelling steady. Over a 10" length I'd say the tailstock alignment is spot on.
Next drilled the end of the rod 10mm deep to take a spigot. The fixed steady kept things aligned nicely.
Next fitted the 4 jaw and clocked in the victim 0.225 drill shank.
Turned down a spigot on the drill shank to fit the hole in the extension rod.
Tested the fit and eased the shoulder with a fine file.
Fits nicely, left a small gap for the silver solder to flow.
Tomorrow it's time to make an alignment jig and braze the two together. Then attempt to drill a 7" long hole through the center of some 15.5mm Delrin rod.
Regards * Danny M *
Edited By Danny M2Z on 09/02/2014 10:05:58
