Many thanks for prompt replies,
Nigel, that’s very kind of you that would be the quickest and easiest way but unfortunately I live down in East Devon.
Russell thank you, never even thought to use my 4 jaw as I follow the YouTuber Enotts Engineering and he did the same thing but used a faceplate.
If there’s one thing I’m learning, there’s a lot to learn.
DC thank you, the back plate mounts up ok in the 4 jaw so I should be able to move forward.
Ok, so bear with me gents, as this will be the first time I’ve done internal thread cutting before. To be clear I’ve done some external threading cutting and internal boring so I’ll probably need to check a few things with you as I go.
Am I right in saying I’ll need a 60 degree tool angle for this thread?
