On
11 December 2023 at 12:07 JasonB Said:
Are you wanting to go to full blown pumped cutting fluid or just something to apply with a brush?
Taking Jason’s question a step further, why use cutting fluid at all?
The fluid controls heat and finish, and may not be needed.
My workshop does relatively little in the way of bulk metal removal. I’m a hobbyist who generally makes small parts from standard sized stock specifically chosen to minimise the amount of cutting needed. For example, I prefer to use Bright Mild Steel rather than Black, because BMS comes with finished sides, that might not have to be milled at all. My cutters have a relatively easy life, and don’t get very hot – short cuts, with plenty of time between them for cooling.
Finish also may not need fluid. When necessary, I improve it by dabbing on neat cutting fluid with a brush, which is effective with light cuts, and helps cool the cutter.
The Cutting fluid is whatever happens to be handy, either CT90 because it’s sold by my local emporia, or a soluble oil which I got from Warco to save carriage costs as part of a larger order. CT90 works well but it’s really for threading, and expensive. The Warco oil is cheaper, but in neat form rather thick, and it’s really meant to be mixed with water. Works well enough.
I also have a pump and tank system filled with an emulsion made from water and soluble oil, or ‘suds’. This is only used when I have a serious amount of steel to remove. Suds is an excellent cutting fluid. Water is a first-class coolant, the soluble oil provides lubrication, and the pump provides the volume and pressure needed to wash swarf away from cutting area. However, the mess suds makes is a serious disadvantage, so I rarely use it. I’d go so far as to say the money spent on the tank and pump was wasted. Not because the system is useless, but because suds don’t match my cutting needs. Another potential problem with suds is that might go off, stink, and infect cuts. Suds caused many amputations In the good old days before antibiotics.
I suspect most home-workshops are in the ‘apply by brush’ camp. The brush advice assumes the cutter is HSS. Splashing hot carbide intermittently with cold coolant is liable to crack it. When using a brush apply coolant to the job, not the insert, or don’t apply any at all. If carbide needs cooling, flood continuously with enthusiasm!
Professional users choose cutting fluids carefully because they remove serious amounts of metal, require good finish, and need to maximise tool-life whilst minimising power consumption. It’s worth their while to optimise, because even small savings add up to big money. The alloy, type of cutting operation, finish, production rate and other factors identify if a particular cutting fluid should be used.
Suds was once ubiquitous. Interestingly, industry are tending to move away from it in favour of exotica like a thin aerosol oil propelled by cryogenic nitrogen. The main reason is cleanliness: the blast blows swarf into a collector, and the clean swarf has a high scrap value because it isn’t contaminated with cutting fluid.
Amateurs don’t have to worry about optimising – experiment with a brush and with whatever cutting fluid is available. Almost anything oily will provide the moderate level of cooling and lubrication needed for light work. I’m not above brushing car engine oil – though it smokes a bit, it’s cheap and readily available! I’d avoid traditional recipes though; they’re mostly bio-hazards. Milk is an excellent cutting fluid, but it putrefies in a few hours and it’s impossible to get rid of the stink.
