An alternative eccentric detail:
NB: this does need sufficient wall thickness on the thinnest part of the sheave.
I am basing my steam-wagon engine partly on the ST design, partly on K.N. Harris’ modification to the Maid of Kent locomotive.
The eccentrics are separate, in cast-iron, cut from stock bar.
To simplify machining at cost of some extra work, I modified the central retainer.
Rather than try to turn two identical steps, machine the rim right across then groove it to match the strap.
The retainer is a split mild-steel ring like a circlip without the end ears, manipulated into place by hand. (It could just as easily be of brass. There is, or should be, very little side-load on it.) The ring could be cut from sheet but is more easily turned, perhaps from thick-walled tube. Ensure some radial clearance to allow the strap to close properly without the retainer binding.
Deburr and slightly round off all its edges. I rubbed mine down on wet-&-dry paper on a flat surface.
Cutting the split wide enough to accommodate a small brass pin in the sheave will stop the retainer from rotating round the groove, though it probably does not matter much if it does.
The launch-link, suspended at the end, was also common on traction-engines, possibly for clearance reasons above the boiler, as well as slightly simpler construction. As with a marine engine these spend most of their time running ahead, so less efficient back-gear events are not so important as on a locomotive that has to run equally well in both directions.
