Posted by Martin Cottrell on 23/11/2013 20:58:37:
. One other question, when you say "nominal size" , does this refer to the pin diameter at its centre, or is it the drill size required to make the initial hole prior to reaming?
The Nominal size is the size that the pin is sold and described at eg 1/16", 1/8" etc
This referes to the very largest end of the pin and infact may be a smidge larger, just measured a couple of mine as an example
1/16" x 1/2" small end 0.053" big end 0.0605" drill 1.3mm (less on your longer pin which will have a smaller point
1/8" x 1" small end 0.101" big end 0.123" drill 2.5mm
I don't see how one reamer will do more than one size though, my 1/16" reamer goes from 0.044 to 0.061 and my 1/8" 0.095 to 0.127 so no way could I ream for a 3/32 pin with them
J
