That boring old silver solder question again
Home Forums Workshop Techniques That boring old silver solder question again
  • #682645
    Bill Dawes
      @billdawes
      Posted many questions on this forum before when I was building my 5″ boiler, eventually finished it some while ago now but I’m having another trauma, still with the boiler.
      I posted recently about drilling and tapping into the boiler for the firedoor hinges, this is what the build instructions for Emma Victoria called for. Having had problems with getting them to seal I decided to drill out and make some blind bushes which I have done. Another silver soldering disaster, Flux (easyflo) overheated I think and just stayed a brown goo, solder melted but wouldn’t flow so gave up as futile to carry on.
      Just deciding now how to attack it again. Now my question is, do I put loads of insulation around boiler (which is what I did) that then means the  flame is only played pretty much all on the backhead as the rest is cosily wrapped up or do I leave it uninsulated so I can get heat all over and keep the torch away from the flux which is what is commonly recommended.
      The confusing thing I have always had is that having viewed many videos over the last couple of years everybody seems to have their own way of doing it, mainly flying in the face of all the classical advice as to how it should be done.
      Well insulated makes sense to me to keep the heat in but having access to all the boiler surface exposed also makes sense.
      Advice appreciated please. I will try again using HT5 flux.
      Bill D.
      Benedict White
        @benedictwhite51126
        I have not had that much experience with silver soldering, but the issue you are having seems to be over heating the flux.
        If you were working on steel your approach might work, but you can heat a 2′ long steel bar to red hot and one end, and pick it up from the other end without a glove on. (This is not recommended though).
        You can’t do that with copper. If one end is red, the other is either red or not that far behind.
        So in effect, you are trying to heat the whole boiler hot enough to silver solder, from a small window.
        What I would do is provide background heat with something cheap and then local heat to get the part you are working on up to temperature.
        Hopefully someone with more experience will be along shortly.
        #682723
        Andrew Tinsley
          @andrewtinsley63637
          If it takes a long time to heat up, then your flux will be toast as you have found. The answer is to use a bigger burner to heat it up quickly.
          Andrew.
          #682728
          Andy Stopford
            @andystopford50521
            In my (limited) experience, insulation round all but the area you’re working on makes it much easier. And use a powerful enough burner.
            #682742
            Bill Dawes
              @billdawes
              I use a Sievert torch and have several nozzles, the one I use to heat the boiler is a 2943, about 43kw I think.  When I first started the boiler I used a smaller burner and it took forever to get it up to temperature.
              I have always had a problem with this insulate or not, even seen a video of a couple of guys on quite a large boiler with two torches, boiler totally bare of insulation, the heat off it must have been tremendous.
              I feel quite frustrated that I am still having to ask these questions, I suppose most of us have an achilles heel, mine is silver soldering (small fittings ok of course)
              Bill D.
              #682748
                Same here.  I think the reason advice varies is getting the timing right depends on the heat capacity of the object being soldered and the size of the torch.  When the flux is heated it cleans oxide off the metal and then melts to keep air away so the solder can wet clean metal and form a sound joint.  Flux only works for a limited amount of time.  It starts losing it’s ability to clean oxide as soon as it warms up, and only forms a liquid seal for a short time.  The joint has to be made before the flux is exhausted, so full-speed ahead.
                An underpowered torch can’t get the metal up to soldering temperature before the flux fails.  Insulation means a less powerful torch can be used, but the combination still has get the job up to temperature quickly enough, not necessarily easy.   An over powerful torch risks cooking the flux before the metal has warmed up.   It’s a balancing act requiring practice.
                My small torch works best with objects roughly a cubic inch in size. Smaller means I have to be careful not to blast the flux, larger makes it hard to get to temperature quickly enough.  Mixed success with big joints, almost certainly because I spoil the flux.
                In one of my old mags LBSC describes how he brazed boilers with a paraffin torch.  The job was placed on top of slow burning coke brazier: I think this provided plenty of heat to warm the job, but wasn’t allowed to get hot enough to melt silver solder or brass brazing rods.   Then LBSC started his big paraffin torch, applied flux to the pre-warmed job, and went straight in with the torch at full power.  I guess timing was important – in the short time between the flux cleaning the surface and melted air-proof layer failing.
                I recall LBSC said to torch the job hot enough to be transparent before applying braze (which needs to be hotter than silver solder).   Not quite sure what he meant by that!  Old school temperatures were judged by colour on the assumption everyone knew what was meant.  They probably did a century ago, but I don’t.  I suspect braziers were operated inside a rather dim shed, not sunlight or a bright well-lit workshop.  I guess the coke took the job to about 450°C, and then the paraffin lamp boosted the joint area quickly to 600°C or hotter.
                The process may require a lot of fine judgements, and I know LBSC had plenty of experience!   I’ve a notion pre-heating the job on a not-too-hot coke bed would make brazing easier, but maybe it was only done because ye olde paraffin torches were weedy compared with a big gas torch.
                Benedict White
                  @benedictwhite51126
                  Silly Old Duffer Dave, I do have some serious paraffin torches, a Radius and a Monitor. Not for the feint hearted!
                  #683205
                  Len Morris 2
                    @lenmorris2
                    Hi Bill.
                    I’ve done several repair jobs or modifications to existing boilers just like you’re trying to do.  Your problem is getting enough localised heat into the job around just the bushes you’re trying to fit.  Sievert gas torches and blow lamps just won’t do it quick enough without heating up the whole boiler to almost soldering temperature.  Buy, beg, borrow or steal some oxy acetylene kit.  The smallest nozzle will bring an area the size of a 10p up to temperature before the rest of the boiler even knows about it.  The flame is very fine and there’s no need to play it directly onto the bush or the flux.  With a circle of solder around the bush it’ll flash to give a perfect job.
                    Len
                    #683348
                    noel shelley
                      @noelshelley55608
                      Lack of heat ! BUT if you do as Len suggests then be VERY CAREFUL that you do not melt the copper. Oxy acetylene, or oxy propane need considerable skill to avoid burning the metal. Initial heating with propane and then the oxy fuel is good. Noel.
                      #683364
                      bernard towers
                        @bernardtowers37738
                        One thing to always remember with oxygen /acet/propane torches is they should never be allowed to be still, always on the move!!!!!
                        #683452
                        Bill Dawes
                          @billdawes
                          Thanks guys, I do have a oxy propane torch (Oxy Turbo) that I bought when I was having my last trauma on the basis that it would get a small localised area up to temp without having to heat the whole boiler, didn’t quite qork out that way to be honest, I assumed perhaps wasn’t quite enough heat, perhaps oxy acetylene is the only way for that to work on a boiler (I do have a friend who is a retired welding consultant and he did his with oxy acet but then he is an expert)  in my recent failed attempt I did put lot of heat into it with my propane torch to start with then used the oxy propane, think I had already burnt the flux at that stage.
                          Trouble with my little oxy propane is that the oxygen does not last that long and it’s not cheap, still getting used to it so at the moment so waste gas faffing about getting the flame right.
                          Still onward and upward, give it another go in a day or two, try it with boiler shielded but not packed with insulation to give access to get the flame around it. Will let you know.
                          Bill D.
