ER32, ER25 or Direct R8 collets ?
Home Forums Beginners questions ER32, ER25 or Direct R8 collets ?
  • #101342
    chris j
      @chrisj
      As some of you may have noted I am getting a nice new Warco VMC mill.
      I'm wondering what collet system to use. I'm favouring the ER32 as I'm not sure that I will have problems with the height of any work or the collet chuck hogging too much space but if I'm honest I'm not sure of the issues.
      What do the panel think ?
      chris j
        @chrisj
        #101346
        Thor 🇳🇴
          @thor
          Hi Chris,
          using R8 collets will give you maximum height between milling machine table and the cutter. To use ER-32 colleets you need a collet chuck, this will reduce the maximum height between table and cutter compared to using R-8 collets. However each ER collets have a 1mm range, so you need fewer collets.
          Thor
          Edited By Thor on 19/10/2012 18:20:12
          #101381
          mark mc
            @markmc72333
            I would use the er32 setup as you can use metric collets to hold imperial cutters, so less collets needed
            #101382
            _Paul_
              @_paul_
              ER32 has a wide clamping range but you will lose around 2" of "daylight"
              Paul
              #101406
              chris j
                @chrisj
                Thanks guys & gals !
                #101837
                Tony Ray
                  @tonyray65007
                  Chris,
                  I have an Sieg SX3 with an R8 spindle I have a set of R8 collets and an R8 ER32 collet chuck. I started off using the ER 32 but soon found that for me working with R8 collets is so much easier. They grip up with far less tightening effort and release easily too. I fitted a spindle lock to the mill which makes the whole thing so much easier. The ER32's do come in useful but they mainly get used on my lathe.
                  Tony
                  #101870
                  I.M. OUTAHERE
                    @i-m-outahere
                    I use ER32 x 3mt as both my of mills and my lathe have 3MT spindles so it is a universal fit .
                    I don't know of a hobby lathe that runs R-8 in the spindle .
                    Ian
                    #499689
                    Paul L
                      @paull58212
                      I need to obtain a new set of collets for my mill (3mt) from reading the above posts I see I have a choice of mt3 'finger' collet or an ER32 collet and nut.
                      Given that the ER32 takes up work space below the spindle what advantages / disadvantages do they offer over the finger collets?
                      (sorry I'm new to this! any recommendations appreciated)
                      regards
                      Paul
                      #499693
                      old mart
                        @oldmart
                        The downside of the er32, is the limited length of the larger diameter tooling that it can handle. I chose er25 which holds up to 16mm, and we have a full set of R8 collets which will hold longer tooling deeper, except for the 20mm one which is limited by the size of the R8 design. Above that diameter I have a 25mm indexable with 3 APHT 16 inserts with the shank turned down to 20 and 18mm in steps according to how much projection is needed. Then its shell mills, 40, 50, 63 and 80mm.
                        #499698
                          I am like XD351, but have five metric collets that go direct in the Mill taper, for when headroom becomes important.
                          I use ER25 and ER 32 collets on the mill and with a Backplate, allowing material to pass through, on the lathe.
                          Facemills and Flycutters are on 3MT arbors for the mill.
                          But you need to use whatever suits your circumstances the best.
                          #499703
                            Range and flexibility. Other collets have much smaller clamping range, whereas ER32 can cope with a full millimetre. 18 collets gets from 2 to 20mm. Modern design (1973), they hold well and are accurate, I use them for work-holding on my lathe as well. Recommended for use with an MT3 mill. (Someone's bound to mention R8, but we MT3 owners have to stay loyal to our choices!)
                            If you get ER32, well worth getting a ball-bearing Nut for the chuck – easier to tighten.
                            No one ever got fired for choosing ER32
                            smiley
                            Paul L
                              @paull58212
                              Thank you for the help.
                              I think I'm going to go with the ER32 set from ARC with a few MT collets for when space is required.
                              Paul
                              #499711
                              Bo’sun
                                @bosun58570
                                Posted by Paul Liddle on 05/10/2020 16:24:18:
                                Paul
                                Sounds like a good solution.
                                #499713
                                Mike Poole
                                  @mikepoole82104
                                  Cutters usually have a limited range of shank sizes so just for cutter holding a limited range of direct collets would be required. To cover all possible sizes if you wanted to hold drills in a collet then ER is very accommodating. I use an ER25 chuck but I have also got quite a few direct R8 collets. One consideration is cutter visibility, with a large chuck and small cutter you tend to see a lot of chuck and not much cutter and the same with small cutters in a direct collet, the spindle nose tends to obscure your view. For small cutter work is can be nice to use a small chuck to maximise visibility. I suppose the answer is that no system is perfect but the ER chuck may be a good place to start. Eventually I suspect most of us acquire a choice of methods. My machine is R8 but I have now got a Clarkson chuck, an ER25 chuck, some direct R8 collets and an MT3 and MT2 adapter which are not overly convenient as you have to eject the adaptor to remove the drill. Other tooling will surely be collected like shell mill arbors, slitting saw arbors, a fly cutter and a drill chuck. Unfortunately there is probably no end to collecting tooling but you certainly don’t need it all on day one.
                                  #499732
                                  Clive Foster
                                    @clivefoster55965
                                    As Mike says cutters come in a very limited range of shank sizes so the versatility of an ER system is basically wasted.
                                    If I were starting over I'd go for end-mill holders such as those from Arc **LINK** and either buy cutters with the flat already fitted or set up to fit my own flats.
                                    Either two of each shank size you use so as to have an end mill and a slot drill set-up and ready to go or go all modern and use three flute centre cutting end-mills for both duties. I'd go three flute now.
                                    Although keeping cutters ready to go in shanked holders is thought of as a CNC concept where seconds wasted in tool changing add up to real money the convenience and faster toolchanging is just as valid in the home shop where we need to make the most of the valuable workshop time eaked out around other responsibilities.
                                    Generally ready flatted end mills appear a little more expensive than the plain shank versions but this is somewhat spurious as true economy range cutters don't seem to be made with flatted shanks so you end up buying a better cutter.
                                    Like Mike I have lots of choices ER, direct R8 collets, a Clarkson chuck and end mill holders. All got for what seemed good and sufficient reason at the time. As I have a good stash of screw ended cutters the Clarkson (Posiloc actually) is my normal go to. The ER system has turned out be the unloved step child. Pretty much never used.
                                    #499741
                                    Roderick Jenkins
                                      @roderickjenkins93242
                                      Posted by Clive Foster on 05/10/2020 17:55:00:
                                      Not necessarily so. Carbide cutters are increasingly affordable. These from Cutwell come in shank sizes the same as the nominal diameter **LINK**
                                      Rod
                                      #499745
                                        There is also the fact that you can hold drills in ER collets so saving the time having to remove MT collets or an ER holder to be replaced by a drill chuck which takes up even more head room.
                                        More so on a moving head mill you will find you spend less time cranking up the head or moving the table to one side when you want to change ER collet size than you need to when removing and replacing a MT or R8 collet
                                        #499752
                                        jann west
                                          @jannwest71382
                                          It's worth considering your wider tool and workholding requirements … e.g. I did the me-math and have er40 standardised across my mill (MT3 – chester's version of the sieg sx3), lathe spindle (sieg c6b), rotary indexer (5c spindexer with adapter), and square and hex (stevenson) blocks. My logic is that I can accomplish workholding and toolholding with one system – and I have two sets of collets ( up to 26mm) and one set of oversize collets which go up to 30mm.
                                          The downside is the mill looses height and rigidity with the additional collet stickout!
                                          I'm trying to workout how I can set up my lathe to have front lever action collet closer that works with er collets, and also a quick-change lever action mt3 toolholder for the mill (a bit similar to the tormach system – but manual) – but those are challenges for another day
                                          Edited By jann west on 05/10/2020 19:33:09
                                          #499759
                                            As always depends on what you're doing! I put a DTI, wiggler, edge finder, fly cutter, slitting saw, miniature drill chuck, tramming tool and imperial and metric twist drills in mine. Also use ER32 for work-holding in the lathe and a Stevenson Block. The whole set's been used, though it's true some of the larger ones haven't seen much action.
                                            Martin Kyte
                                              @martinkyte99762
                                              Posted by SillyOldDuffer on 05/10/2020 20:21:21:
                                              There is no law to enforce the buying of the complete collet range. Just buy the chuck and the collets you need.
                                              regards Martin
                                              #499768
                                              Vic
                                                @vic
                                                I started with a couple of MT3 finger collets as I was on a tight budget. I rarely use them though since I bought an ER32 collet chuck. If you’re buying an ER32 chuck buy yourself a “bearing nut” for it as it makes tightening easier.
                                                ER32 is a good choice as there seem to be lots of other fixtures and fittings in that size. You can also get over size collets for the ER32 up to 1”.
                                                #499780
                                                Nick Wheeler
                                                  @nickwheeler
                                                  For what they cost, not buying the whole set of ER collets is daft. Having to delay a job you could finish now if you had a collet that is part of a set is a very poor use of resources.
                                                  If your intended use is on the mill, then getting the Stevensons collet blocks will make a lot of operations easier: cross-drilling, machining flats, hexes etc.
                                                  #499783
                                                  Clive Foster
                                                    @clivefoster55965
                                                    Thats an impressive list of things to put in an ER collet. I have a brace of nice Albretch drill chucks to deal (more) quickly and easily with most of those. Tramming device (Burk Co-Ax knock off) goes in a direct spindle collet. Slitting saw arbor and fly-cutter are direct to spindle shanks. The idea of futzing about with a collet to hold drills almost makes my ears bleed. I have done it with oversize straight shank drills for one off "why did I agree to do this" types of job and hopefully won't be revisiting the experience.
                                                    The Stevenson blocks, spindexer and work holding in a lathe possibilities are the best arguments in favour of a comprehensive ER system. But my main lathe is native 5C spindle taper and I have full sets of 5C by 1/64" and 0.5 mm so ER has no attraction there. Obviously my spindexer, hex block and square block are 5C. All get regular use. Great thing about 5C is being able to get hex and square collets when needed.
                                                    To my mind, except a lever action closer on the lathe, popping a native arbor out of a spindle is always going to be faster and less hassle than mucking about with collets for everything. Been mimbling whether or not to fit my lever closer for ages!
                                                    One great thing about this hobby is that there are many ways of doing things with considerable overlap between methods. What you do is always constrained by what you have. Given most folks budgetary limitations the art is to get what you need now and for the foreseeable future without exhausting todays funding. No point in overspending on tool holding and tooling in early days leaving no money to get materials and actually use the stuff.
                                                    In retrospect I spent far too much far too early in anticipation of what I might need! When an absolute "must have now 'cos I shall surely need it" sits in a cupboard for 30 years before triumphantly emerging to save the day its possible the need was overstated! Hope is fading for some 40 year and counting cupboard queens. I shall use my Edgwick (Cincinnati copy) dividing head one day. I will, I will! Got the wide range plate set too, how cool is that!
                                                    Bargain prices tend to have undue influence on me too.
                                                    If I were to do it again starting now I would go with several end mill holders, a good keyless chuck, direct to spindle arbours for slitting saws and flycutter, possibly a direct to spindle collet for the tramming device and wiggler / edge-finder too. Actually I'd ditch the edge finder and buy a Huffam type wiggler, more spendy but they work properly, always. I'm unconvinced about collet blocks unless your mill is small. 5C spindexer and 5C mount chuck could cover all collet block duties for me. The blocks only tend to come out when I can't be bothered to fit the spindexer or when I have vice set ups going on at the same time. Clearly if you eventually do decide that an ER or whatever collet set is your future way forward then starting out with a collet set will probably be cheaper.
                                                    One place I would spend out on is a good machine vice. If the size is appropriate for your machine the Vertex VJ400 is a decent vice with much larger opening capacity than the normal 4" jaw vice. Spendy at £250 (ish) from Rotagrip but I'd find an ordinary vice limiting.
                                                    #499843
                                                      Posted by Clive Foster on 05/10/2020 23:07:12:
                                                      Thats an impressive list of things to put in an ER collet. …
                                                      It's what our machines are used for and how that makes the difference. Most of what I do can be done by changing collets, which is quicker on an MT machine than undoing the drawbar and swapping the whole tool. Not everything is suitable for collets though: boring heads go in the spindle, and it's well worth changing to a drill chuck when a job requires a lot of different sized holes to be drilled. But most of my drilling is done with collets. Other examples too.
                                                      I'm in two minds about sets and buying in anticipation. Sets have two advantages: they solve the "I don't know what size I need yet" beginner dilemma, and – provided most of the set is eventually used – they're cheaper than buying one at a time. Also, owning sets saves time if they avoid jobs stopping dead while a tool is ordered. On the other hand, I've wasted money on a few tools that have never been used. It always hurts.
                                                      sad
