Hi
Your reference to the inconsistent feed rate is a factor
In the early 70’s I could break parting tools on the school lathes with ease
my dads reply was it’s only a toy lathe , they are not rigid enough ,
followed by – don’t be timid you have to go for it and be consistant with the feed
several years later I was co-opted into making reapairs to the controls on a EMI-MEC Sprint plug board capstan lathe.
watching the war issue BSA auto’s , DANOBAT 40’s and 50’s , and EMI-MEC’s running
the first thing that I noticed was the parting tools were thinner than than I remember on the school lathes
also depending on the machine mounted on the rear or vertical slide
and very close to the collet chuck
Interestingly one machine was being used to cut up some 1/2″ x 1/4 “
brass bar into thousands of pieces about 3/4″ long to make adaptors for some switch gear
two lengths of bar being feed through a 1/2″ square collet to a stop and the parted
the machine run for days just needing to be supplied with new bars !
starting virtually from square one at the start of the year with a CL300M lathe that needed some attention to the speed control etc
my first attempt at parting took me back to my school days
the toolpost deflected forward and the workpiece trying to climb onto the tool
I’ve now solved my problem
It just took new taper bearings , new gibs and a lot of work ensuring nothing move when it should not do so
Edited By john swift 1 on 03/10/2010 12:00:33
