Thank you Gordon and Martin.
Some progress made
The manufacturers on the brochure are not, apparently, the makers of these particular shutters although the design is similar. Spare parts may be unavailable.
Re. the size/weight issue, the headbox was supported on two square section ‘spigots’ (for want of a better word) approximately 1″ sides and 2 – 3 ” long, which were part of the endplate castings. These were inserted into the tops of the two side guide rails for the shutters, these guide rails being attached to the wall with 4 off 8 gauge screws each. These have broken off. The whole lot, including roller shutter, motor, drive tube, headbox etc. was a fairly easy lift/carry – so maybe 30-40 lbs?
The intention, at the moment, would be to make up aluminium angle brackets, say 1/4″ thick and 2″ ‘legs’, 1″ wide pop rivetted to the remains of the existing end plates and then attach these to the wall. The guide rails would no longer support the headbox. The end plates are about 6″ square but the rivets would have to be positioned to avoid the roller blind when it’s back in the headbox. Perhaps two brackets on each plate (top and bottom) for insurance?
If that works, several coats of quality paint, as Gordon suggests, might increase the life-span? Apologies for the ramble but I’m trying to test the possibilities on a knowlegeable audience, working from a personal knowledge base close to zero
Rgds
Bill
