Chuck Backplate Problem
Home Forums Beginners questions Chuck Backplate Problem
Viewing 3 posts - 1 through 3 (of 3 total)
  • #51699
    Apostolos Bourousis
      @apostolosbourousis64808
        Hello dear Friends and warm Greetings from Greece
      (Yes we are still alive after EMF Visit !!!)
      Recently a friend of mine give me free a 2nd hand Chinesse lathe that i try to restore and use it as is very nice machine and i be very happy to have it in working condition .
       My problem is that lathe come without chuck or backplate and as i dont have a large machine to fit an un machined  casting backplate and work it i must found a new or used backplate with already made the thread to put it on my lathe and then to make the facing and grooving operations on the lathe to fit .
        I look on the web to find the right backplate but i cant find what i need as all the backplates are on Imperial dimensions .
       My spindle is 56.5 mm or when i turn my caliper on inch shows 2.225 in.
      The therad is 8 TPI . can some friend help me what type of backplate i need please ?
      I suppose the Chinesse designer copy some other lathe but which lathe have this spindle ?
      My very best regards and many thanks in advance together with a very big sorry for my English as i am totally self learned .
      Apostolos
      Athens
      Greece
      Apostolos Bourousis
        Where i can find a part machined backplate for my lathe
        #51700
        Speedy Builder5
          @speedybuilder5
          I suspect you have a 2.25 x 8tpi spindle. ie 2.225 inch would be the diameter over the crest of the thread??
          The Logan 11 inch had a 2.25 x 8tpi  try Tony@lathes.co.uk
          Also the Southbend 10L (Bit of a rare USA beast)
          But be carefull,  the spindle nose boss diameter is important as this locates the backplate.  I you cant find a backplate, try one of the engineering services in the back of Model Engineer magazine.
