Martin – tool sharpening. I agree – when the devil rides etc. The only problem is that if one is a bit of a beginner it might not be so easy to grind one up, and a good preformed carbide one might help isolate the problem. Mind you if AES has a tool that can routinely take .001 cuts he should be quite a dab hand on the grindstone – better than me.(but not as good as the Quorn
) (actually Quorn is out, tangential is in
This has sort of spread into a wider issue,
first question is how do you know it is not rigid? (Apart from the fact that its sitting on a hexagon nut which needs replacing with a fat flat machined “washer” the width of the toolpost block ASP.)
Is it chattering or what?. Is it turning taper, moving in the chuck, flexing in the bearings or is it simply badly adjusted gib strips. It could just be a blunt tool pushing the work away.
If it is actually that floppy I think one may well be outside the scope of a forum like this. Not that there isn’t the expertise, but its in danger of getting a little long winded.
I would suggest you make a list of all the joints” in the system – saddle gibs, x slide gibs, tool post, tool boat to post, tool to holder etc. Adjust and square each and every one and check with a DTI to see if there is improvement. When you find an improvement its worth taking a trial cut.
I’ve just been through this pain, because my 2 year old Chinaman suddenly started to misbehave. It was turning perfectly straight using tailstock support, but taper with inconsistent sized cuts (occasionally) without support.
Basically a microscopic chip of paint was on the gib strip and prevented it from adjusting properly. So with a bigger cut the clearance allowed the slide to rock, but not on a smaller cut. That sorted the inconsistency, but it didn’t sort the taper.
Working on the basis that if its cutting straight with the tailstock support. but not without, its got to be the way the work is held. Chuck or bearings. Change chucks and try. Still the same. Got to be bearings.
£156 saw me the proud possessor of a pair of P5 grade precision bearings and the machine is fine again. Actually it is stunningly good and is turning straight to 5 hundredths of a thou in 8″.(for the time being – not bad for a cheap old Chinaman. My mike doesn’t go below hundredths)
So its just a matter of working logically though the machine, altering one thing at a time until you get it right.
Above all don’t get tempted to dodge about following this and that advice, which is what will happen if you keep this on forum. Martin I am sure has it taped – stay with him and just plod though it logically and you’ll find the problem quite quickly.
A lathe after all is not a very complicated thing.
