You will not pull much tighter than that with half-hard 15mm copper.
The solution to getting around such a tight bend would be to fit an elbow at the appropriate point.
Maybe a street bend if you have one of a suitable radius, but then you would have to socket form or put a connector on one end of your tube.
You can also get pre-formed return bends if you are trying to make a 180 degree return.
(You refer to annealed tube, I’m assuming that you are actually working with half-hard tube. Fully annealed copper risks collapse in a pipe-bender, anneal the tube if you are using springs.)
