If I’m clamping something down direct to the table I give her a scientifically judged bit of welly – actually I’m quite careful not to distort it, (by using a cut down spanner) and only 3 points of contact.
But my point was that if you are using sheet metal covers, and as was intimated, one might be clamping onto such a thing, then to get a vice to sit flat to engineering limits, yes you’d have to use a torque wrench, since all things are elastic. That is something that is a bit overmuch trouble for me.
I’m not against covers – most of my kit is covered when not in use – and I have some ply thingys to put on the lathe bed when changing chucks to make sure the bed doesn’t get damaged. I made sure I spent a fair bit of time an dosh coverng DRO scales. But with the greatest respect to those who feel covers are useful on a milling table – damned if I can see it.
Sheet over the machine at the end of the day – sure. But to leave plates on the bed, under which some coolant will sit, ready to promote bacteriological staining , or to try to keep swarf out of slots which will collect some anyway?
Not for me.
Mowever, I like the magnet/polycarbonate idea for a vertical splash screen Using tips under a good coolant flow, with 2″ facing cutters the overspray can be a bit broad!!!
