You COULD quite easily start a carbide/HSS flame war with this one Gordon, BUT, HSS is sharpened using a conventional grinding wheel so you can have more stabs at the offending material without damaging Carbide tips or inserts.
Problem with unknown materials is just that. As a newbie, (And to be asking this question doesn’t take rocket science to work out) you should restrict yourself to materials with known properties before commiting yourself to rubbish (In material terms). Once you’ve got how to sharpen tools to machine KNOWN properties, then you can deviate.
Basically you’ve told us it’s Metal. Turning speed?? Coolant?? What colour are the chips coming off?? What SHAPE are the chips??
I’m NOT mocking OR taking the ——- micky, but these are salient features.
MOST Carbides don’t like intermittent cuts, but I’m not discounting them, It’s just that I preferr to do it properly and use HSS.
Regards Ian.
