Ian – perhaps my boy can bring some back for me. He takes up a job catching mice in the New year – we tease him. Ground nesting birds is the serious part of it.
Tony – I don’t think you have a problem. That is a nekkid firefox, so you can still get at everything – the difficulty is getting the heat inside, and you still have to drill etc for all the stays.
What you need to get the heat inside, and you’ll need one anyway to do the stays, is a cyclone burner to fit the torch. If I’m not telling my granny – its an ordinary burner on its own swan neck. At the outboard end of the swan neck is an air admission port. This means it will take its own air in to the flame, and it will stay alight in a confined space.
You will then be able to touch up your soldering and get the stays done as well.
Also, at that point, how big a burner do you have? The BIG Sievert one should fry that firebox quite easily. So you may simply not have enough heat.
That is what it looks like with all that SS all over the place. Get the whole joint properly hot and fluxed and the SS will flash along the whole joint, and because the biggest heat reserve is in the joint, and because of capilliary action, it stays IN the joint, so you get a very neat line of braze.
Forgive me, but it looks as if you are trying to solder with marginal heat. Also from what you say, you are putting the rod in the flame?
As a suggestion- get the joint hot (dull red) before a rod goes anywhere near it. The flux has gone all clear and sort of mobile. Move the torch a touch forwards of where you want to solder by a little bit to keep the heat up. Touch a fluxed rod to the area and it should melt and flash down the joint, without 1/2 melting the rod and giving it the droops and the blobbed ends. If you have a long linear joint you can keep pulling the solder along the joint with heat and keeping the rod well fluxed.
Again at the risk of grannnys.
1 You must have a gap INTO which the solder will flow, so centre pop all joints to keep them marginally apart by a couple of thou.
2. The heat to melt the rod comes from the base metal and not the flame.
More economical too. You are trying to silver solder the joint, not the boiler.
Edited By meyrick griffith-jones on 20/12/2009 09:56:08
