5 Cylinder Rotary Air Engine
Home Forums Miscellaneous models 5 Cylinder Rotary Air Engine
  • This topic has 23 replies, 11 voices, and was last updated 23 May 2020 at 23:23 by duncan webster 1.
  • #4285
    Nigel (egi)
      @nigelegi
      Nigel (egi)
        @nigelegi
        Not sure where to post this as this is a rotary compressed air/steam engine designed to drive a propeller. 9mm bore and stroke and all designed by me, sadly I only have one rough sketch to go by. There are a few more details on my gallery pages and I do keep wondering if I should create some plans, just not sure how much interest there would be.
        #371908
        Nigel (egi)
          @nigelegi
          The image doesn't give away the size of this engine and so thought this image might help.
          #371909
          Wout Moerman
            @woutmoerman25063
            Very nice! I am very interested in compressed air engines and would love to see a plan or sketch. The porting is I n the rear of the crankcase? Can you explain the mechanism a bit more? Just 1 opening in the stationary part?
            #371911
            Wout Moerman
              @woutmoerman25063
              And what kind of plane will it fly? Any idea for a airtank? Or am I getting carried away?
              Edited By Wout Moerman on 15/09/2018 21:36:45
              #371912
              Nigel (egi)
                @nigelegi
                Yes, the air goes in through the crank, which is stationary, this then comes out through the side of the crank and so is timed into each copper pipe that takes the air to the cylinder head. The piston is pushed down and at the bottom of the stroke there are holes in the side of the cylinder to let the air out.
                #371913
                Nigel (egi)
                  @nigelegi
                  Posted by Wout Moerman on 15/09/2018 21:24:47:
                  And what kind of ane will it fly? Any idea for a airtank? Or am I getting carried away?
                  It took quite a long time to build and must admit that I probably won't build a compressed air tank or flash boiler.
                  Although it would look good in a Sopwith Camel or similar aeroplane.
                  Maybe some plans so that someone else can go the hole way with the build
                  #371914
                  Nigel (egi)
                    @nigelegi
                    The piston and master corned with a 2mm drill acting as the gudgeon pin
                    #374240
                    Steve Crow
                      @stevecrow46066
                      Hi Nigel, I'm very impressed with this build. I still can't get my head around the way the air intake works. Maybe you could post some more photos or a sketch to demonstrate.
                      I'm making a flat twin at the moment that uses a ball valve for the intake, similar to Gasparin Co2 engines.
                      Cheers
                      Steve
                      #392489
                      Jordanbelfort
                        @jordanbelfort91109
                        Nice and very informative post…
                        #392505
                        Howi
                          @howi
                          +1 for plans please
                          #392547
                            A compressed air version of the Gnome, Le Rhone,or Clerget. Excellent!
                            #392571
                            J BENNETT 1
                              @jbennett1
                              Just curious, but why did you go for a rotary engine rather than a radial. Also, have you any idea of power output and air consumption?
                              #392660
                              Nigel (egi)
                                @nigelegi
                                Not sure really why this configuration, but I sketched a rough idea and started by making the crankcase that is shown in the video **LINK**
                                The crankshaft is fixed and the air enters the end, comes out halfway down and enters one of the copper tubes – the tube will be the one connected to the piston that is at Tec
                                #392661
                                Nigel (egi)
                                  @nigelegi
                                  I've not measured the power or air consumption and not pushed it too far – it runs and has become a showpiece sadly
                                  #392686
                                  daveb
                                    @daveb17630
                                    I recall fizzy drinks bottles being used for on board CO2 tanks. Can't remember how much pressure they would take but it was a lot. Should be easy enough to pressure test a few bottles with a boiler test set.
                                    #392688
                                    Nigel (egi)
                                      @nigelegi
                                      It would be nice to build a sopwith as an indoor free-flight model. The air tanks used for paintball might be a way forward
                                      #392729
                                      Ian S C
                                        @iansc
                                        daveb, the ones with soft drink bottles used air pressure, the CO2 motors used the little CO2 gas cylinders.
                                        Ian S C
                                        #392735
                                          Posted by daveb on 23/01/2019 22:14:16:
                                          Quite a few people, many of them not very bright, have pressure tested plastic bottles. The most common reason is they want them to go bang! Mostly they report attempts to measure burst pressure, and their methods aren't likely to be accurate.
                                          The highest burst figure I've seen was about 300psi, the lowest 80psi. Mythbusters reported bursting 2L bottles at about 150psi – they're more credible source than most,but don't get everything right!
                                          Safe working pressure is another matter. One source claims the bottles are designed for 120psi and – in normal use – the internal pressure doesn't exceed 80psi. The other issue is the number of cycles the container can safely do before weakening. As plastic bottles are disposable it's unlikely the makers rated them generously. It's also unclear over what temperature range the bottles are safe. Cold would tend to make the plastic brittle and heat would tend to soften it.
                                          If you know what you're doing, I don't think it unreasonable for a model maker to deliberately take the risk that his plastic bottles might explode. The amount of energy stored in the bottle is low. It's not in the same league as a boiler. Although the bang is loud enough to damage hearing and flying plastic might damage eyes, I think gloves, ear-defenders and protective glasses would be sufficient protection. Provided you're not actually holding the bottle when it goes off, that is!
                                          Liquid carbon dioxide – as stored in a Sparklets bulb – is about 900psi.
                                          Nigel (egi)
                                            @nigelegi
                                            Posted by Howi on 23/01/2019 09:20:21:
                                            +1 for plans please
                                            I only have a rough sketch and no cae ability, sorry
                                            Edited By Nigel (egi) on 26/01/2019 20:33:18
                                            #393200
                                            Ian S C
                                              @iansc
                                              Only a rough sketch, that's often more than I have when I build on of my hot air motors.
                                              Ian S C
                                              #393207
                                              Nigel (egi)
                                                @nigelegi
                                                This was the limit of the plans that I constructed – really just to check the master and slave conrod clearances
                                                #474264
                                                Nigel (egi)
                                                  @nigelegi
                                                  With lockdown I've been running more of my old engines and thought this was rather fun, the 5 cylinder rotary runs on what is effectively not much more than a fishtank pump, in this case it's the air pump for the lumbar support in a car seat.
                                                  I need to create some drawings as it runs so well.
                                                  #474379
                                                  duncan webster 1
                                                    @duncanwebster1
                                                    Posted by Nigel (egi) on 23/05/2020 16:39:13:
                                                    Very nice, an interesting project, get it written up for ME
                                                  Home Forums Miscellaneous models Topics
