Hi all, newbie with first lathe, rare one i think.
Home Forums Introduce Yourself – New members start here! Hi all, newbie with first lathe, rare one i think.
Viewing 25 posts - 1 through 25 (of 63 total)
  • #41160
    wayne ollerenshaw
      @wayneollerenshaw89933
      Thor 🇳🇴
        @thor
        Hi Wayne,
        I assume you have already checked lathes.co?
        Thor
        #567169
        Brian Wood
          @brianwood45127
          Hello Wayne,
          This particular lathe is the very one pictured in Tony Griffiths excellent archive website http://www.lathes.co.uk. Other than confirming it came off a WW2 German warship and having a spindle height of about 7 inches from the bed, he has rather uncharacteristically little do add, except to say the factory produced quality work.
          There are no technical details that you can refer to. The view inside the headstock is of a clean machine in good shape.
          Enjoy your purchase, it should serve you well
          Brian
          #567171
          wayne ollerenshaw
            Posted by Thor 🇳🇴 on 17/10/2021 18:41:44:
            Hi Wayne,
            Thor
            Hi there, yes thats the one i have.
            #567172
            old mart
              @oldmart
              Welcome to the forum, Wayne, it certainly is an interesting machine. I would personally choose a 1 hp motor, 0.75Kw and a VFD since its quite old and needs a gentle touch. And keep the maximum rpm below 1400.
              #567173
              wayne ollerenshaw
                Posted by Brian Wood on 17/10/2021 18:42:39:
                Hello Wayne,
                Brian
                oh its clean, in all very good condition really but for a bit of damage on the cross slide.
                I am trying to find out the oil to use to add to the head stock and oil ways, i want to give a service if needed or not as dont know when it was last done.
                #567174
                wayne ollerenshaw
                  Posted by old mart on 17/10/2021 18:58:33:
                  I have been wondering why it has a three belt pulley also. any ideas why that is. it looks original
                  Oh and yes i dont want to blow it up even though its built well i want to be carefull with it.
                  #567176
                  Dave S
                    @daves59043
                    My CVA has 3 v belts from motor gearbox output to the headstock. I guess it’s for torque transmission.
                    Dave Halford
                      @davehalford22513
                      If it was born with a 3 pulley drive it probably needed it.
                      You may find the gearbox very lossy and it's got a heck of a bed for a bench top lathe. With a 14" swing it's more like 3hp territory.
                      #567178
                      Nigel McBurney 1
                        @nigelmcburney1
                        I would be looking at a minimum of a two HP motor to drive your lathe ,thats a big headstock to drive,plus cut metal,the multiple drive pulley indicates that it originally had a good size motor.I would not try to get a high spindle speed,if it is ww2 ,a spindle speed would not been much over 750 rpm. In the 1950s a 8inch Wilson lathe i worked on had a top speed of 440 rpm and a 41/2 Boxford was only 1450 rpm.
                        #567179
                        wayne ollerenshaw
                          This is why i am trying to find the origin al specs on this lathe. Its amine field for me all this as in what size motor as folk have said all between 1hp and 3hp and speeds from 500rpm to 1750rpm.
                          I plan on a 3ph with a VFR, now with a VFR can i make the VFR max out at say 1400rpm ?
                          all new to me this also, just learned the other day what a VFR does.
                          #567180
                          wayne ollerenshaw
                            I am bidding on a 3ph 1.5kw/2hp 1450rpm motor on ebay. should i leave it and see. dont want to buy the wrong size now.
                            Its always the way with me, i buy things that need so much research ha ha
                            Edited By wayne ollerenshaw on 17/10/2021 19:56:25
                            #567188
                            old mart
                              @oldmart
                              If the motor looks good, go for it, you don't have to run it at its limits. A decent modern oil of practically any type will be superior to the stuff they had 80 years ago, I would use synthetic motor oil myself.
                              #567189
                                Hi W.olly, welcome over here.🙂
                                Get the 2HP motor. Have you checked the threads on any of the bolts and measured the lead screw pitch (travel per rev) yet?
                                You won’t break it if you are careful. It is built like the proverbial brick bog.
                                Ipswich is a bit far for me, but I expect there are some nearer, who could give you some practical on-site advice- sort out your accessories and get that indexer working.
                                The better VFDs can be programmed for all manner of things.
                                Edited to add: Check the type of bearing on the headstock.  If it is a plain bearing stick to the 1000rpm  limit – well not much more.  If a taper roller bearing, the main spindle could go much faster but the gearbox may not like it.  It would be a shame to push it too hard.
                                Edited By not done it yet on 17/10/2021 22:04:10
                                #567198
                                peak4
                                  @peak4
                                  #567233
                                  old mart
                                    @oldmart
                                    We all look forward to regular updates on progress with your lathe. Have you measured the spindle threads and fitting? You will probably have to make custom backplates from blanks or solid cast iron for any additional chucks needed.
                                    #567235
                                    peak4
                                      @peak4
                                      Posted by Nigel McBurney 1 on 17/10/2021 19:35:47:
                                      If you have a look at the second link in my previous post, there is a photo of the brass plate showing spindle speeds.
                                      If I read it correctly selectable up to 1000 max, but 1200 is also mentioned at the bottom of the plate, perhaps for a higher frequency supply.
                                      Note also the photo of the lathe fitted with two different motors at the same time.
                                      Bill
                                      #567257
                                      Brian Wood
                                        @brianwood45127
                                        Google has some information from Suffolk Steam on this particular lathe, It is demonstrated in a video
                                        The nose thread is 60 mm O/D, pitch 5.5 mm with a through bore of 40 mm and 5 MT nose taper. From the size of the bearing housing I would guess at a taper roller bearing support at the chuck end and probably a plain roller bearing at the far end of the spindle
                                        Old Mart recommends a decent quality oil in the headstock. I agree with him and used a semi-synthetic 10W-50 oil made by Morris Lubricants in a recent restoration of a Churchill Cub lathe of 1947 vintage. It seems to like it and runs very well at all speeds.
                                        Brian
                                        #567268
                                        wayne ollerenshaw
                                          Posted by not done it yet on 17/10/2021 21:52:54:
                                          Well ow do there kida
                                          I won that motor
                                          Think you mistaken though as i am in Manchester and got he lathe from Ipswich, but i do confuse folk much like i confuse myself ll.
                                          I havnt yet counted the leadscrew. ill pop out in a bit and do so though.
                                          #567269
                                          wayne ollerenshaw
                                            I found a couple of them the other night and started to go through them, that lathe though is different from mine. well a little. head stock look similar.
                                            All i can say is thank god for translate
                                            #567270
                                            wayne ollerenshaw
                                              Posted by Brian Wood on 18/10/2021 16:35:10:
                                              Brian
                                              That is mine from Suffolk Steam. Andrew there is the bloke that sold it on to me.
                                              #567272
                                              Brian Wood
                                                @brianwood45127
                                                Well then, Andrew at Suffolk Steam is the man to ask for any other information, the rest of us are floundering about without a lot to go on
                                                Brian
                                                Edited By Brian Wood on 18/10/2021 18:20:34
                                                #567275
                                                wayne ollerenshaw
                                                  Posted by Brian Wood on 18/10/2021 18:20:13:
                                                  Brian
                                                  He told me all there is to know. Just a chap sold it to him from a workshop clearance. his dad who was high up in the Navy got to have the lathe from a WW2 German Navy boat that was is Londonderry. he used it for model making for years.
                                                  #567278
                                                  wayne ollerenshaw
                                                    Just done 1 rev on the screw feed and got 6 threads and 1.25", does that mean anything kida ? The cross slides etc are imperial i know that much. 10 turns to an inch.
                                                    #567344
                                                    Brian Wood
                                                      @brianwood45127
                                                      6 threads and 1.25 inches. Means nothing at all.
                                                      A more meaningful result would be to measure as best as you can the carriage travel for10 full turns of the leadscrew to reduce reading errors
                                                      I suspect it will be some metric value. The other feed screws may have been replaced with imperial versions by the previous owner, a relatively simple modification when compared to changing the leadscrew as that would also change all the results for screwcutting from the gearing tables giving the various arrangements and their results in thread pitch.
