OK, I can see there are a few things to consider.
My Bantam seems to have a single speed motor, because the switch is only On and OFF. I will see if the plate states otherwise,( though I dont really know what Im looking for). It came with a variable speed inverter, so initially I ran it off my single phase supply.
I did make some (probably bad) assumptions. …………..
1. It felt a bit "weedy" (probably the soft start).
2. If you have 3 phase, everything should be on it…. you will have more horsepower, which HAS to be a good thing.
3. I didnt think that the fastest speed was fast enough, in either inverted form or with the single speed 3phase motor. When tuning small jobs, I thought I could do with more revs. (I didnt put a rev counter on it in either form though.)
So the easy thing to do was to take off the inverter, and re-jig the connections to give me 3 phase. Then I read about the 2 speed motor, so that has become the Holy Grail. Just how my mind works!
Thanks for the advice so far, please let me know what you think.
Tom.
Edited By Tom Walker 1 on 13/08/2020 14:02:48
Edited By Tom Walker 1 on 13/08/2020 14:24:29
