New member in north east
Home Forums Introduce Yourself – New members start here! New member in north east
  • #458513
    Kris Gilyeat
      @krisgilyeat51031
      Hi all
      I'm just introducing myself I'm looking to start on a big project soon 4" traction engine or similar I'm sure I will find loads of good advice on this forum
      I am a mechanical engineer by trade and use alot of Cad mainly solidworks so I hope I can offer some knowledge in that sector
      Thanks Kris
      Kris Gilyeat
        @krisgilyeat51031
        Introduction
        #458750
        David George 1
          @davidgeorge1
          Hi Kris welcome to the forum. I'm not a steam person but always amazes me on the amount of work needed to make a traction engine. What machinery do you have as it helps when you hsve a query etc.
          David
          #458751
          mechman48
            @mechman48
            Welcome Kris.
            Where about's in the NE are you located.
            George.
            #458767
            Steviegtr
              @steviegtr
              Welcome Kris.
              Steve.
              #458783
              Anonymous
                Welcome to the forum. I was in the north east over the last few days retrieving my glider; could have dropped in for a chat. smile
                #458786
                Brian H
                  @brianh50089
                  Hello Kris and welcome.
                  Brian
                  #458923
                    Welcome to the forum Kris,
                    Harry Wilkes
                      @harrywilkes58467
                      Welcome smiley
                      H
                      #458952
                      Kris Gilyeat
                        @krisgilyeat51031
                        Thanks for the warm welcome guys.
                        I'm near hartlepool but other side of the A19
                        I've got a warco gearhead lathe and mill so prett
                        y well kitted out and I've got access to bigger gear at work if I need it.
                        I'm looking forward to getting started on the traction engine ive got a few othe projects to finish first. Looking at part built options at the moment the main bit I'm planning on "Subbing out" it the boilder even tho I work at the place that produces the pipe that the boiler will probably be made from.. but I think easiest way to get a certificate is to go to a specialist
                        Let me know if anyone dissagrees with the above I'm in no rush so anything's possible.
                        Kris
