Plenty of wiring diagrams out there to fix that .
If you don’t want a certain voltage rail like 3.3v or 5 v or a negative rail just leave it disconnected .
When you open up a supply just identify the voltage you want by either wire colour code or looking at the board as it is sometimes written on it and unsolder the wires from the other pads then trim off the wires you won’t need from the supply rail you won’t use or as i did remove all the wires and solder on some heavy duty cable to the solder pad for the voltage i wanted to use .
Seriously these power supplies are something that many model engineers overlook because we don’t understand how they work or don’t know how to utilise their ability, you can get a 20amp , 12 volt pc power supply for under $50au here in OZ from just about any computer shop and even more power is not that much more expensive considering my local electronics shop would ask well over $100 au for something similar in their power supply units .
P.s , Dave slotted in a reply while i was typing this and as he says – the OP is not electrically minded so the power supply that Dave shows is the simplest approach – i have never had a problem running motors off them and my cnc engraver uses the exact same type for its spindle motor but utilised the voltage control potentiometer as an RPM control via a remote potentiometer instead of the trimpot on the circuit board .
Edited By XD 351 on 31/08/2019 10:44:37
Edited By XD 351 on 31/08/2019 10:54:39
