Hi, thanks for your kind responses – apologies for my late reply, I'm currently in process of completing the actual move itself..
I guess that the two projects currently underway illustrate the kind of things that I enjoy doing – I'm cobbling together a Heath Robinson tool grinder from the scrapbox, mainly in order to achieve greater accuracy in such items as threading tools, and reduce the tedious cycle of "offer-up & adjust slightly"..
Whilst I'm happy grinding most tools off-hand, it IS something that I find has to be done regularly to achieve any sort of efficiency – once it's almost habitual, it's a breeze, but when one has to contemplate the moves, it's a bore.
The other project is a little Cyldon that was handed to me as a boot-sale find. The boiler was intact, as was the pipework, cylinder support bracket/port block, burner, and whistle. Rather than a thorough restoration, I've had a surprising amount of enjoyment carrying out a fairly pragmatic repair, making a fabricated flywheel, replacement cylinder and piston, and a safety valve on my little Hobbymat. I'll try and upload some pictures.
I find that I've reached that point in my life when small steam engines are starting to exert something of a pull.. I will have to build one from scratch.
Other than that, and perhaps in common with many other members here, I carry out the usual range of domestic repairs & replacements, and the occasional bit of free ("I don't suppose you could make me a…"
motor engineering for friends and family.
