Old member returning
  • #40539
    Graham Porcas
      @grahamporcas42677
      Graham Porcas
        @grahamporcas42677
        I used to be a member on this forum but fell off the edge some years ago, there must be few old posts of mine knocking around somewhere.
        Now back because I am actively looking to purchase a running 5" tank loco, must be GWR
        #410459
          Just read your 2 postings from 2009. The rear toolpost parting is STILL a common topic, even ten years later!
          Did you build your own mechanical hacksaw?
          #410460
            #410492
              The prodigal returneth! Welcome back Graham.
              Graham Porcas
                @grahamporcas42677
                Gentlemen
                Thank you for your unexpected welcome back!
                I had forgotten exactly what it was I posted about before and am glad to see that it was nothing too embarrassing although I have gone off carbide tips and am back to HSS.
                The rear tool post is still in daily use and sworn by rather than at, I don't understand why this should even be a discussion point as it makes parting off such a simple and satisfying process.
                I didn't buy the Blackgate as I eventually found an old (very old) Rapidor which I saved from the scrap yard when I heard about one being thrown out during a purge, also in near daily use and much appreciated although finding 14" blades is a problem. Might be a topic for a new thread? How to make donkey saw blades?
                Best Wishes
                Graham
                #410538
                Zane Crowther
                  @zanecrowther67531
                  Welcome back to the forum Graham!
                  Best regards
                  Zane
                  #414195
                  Mike Poole
                    @mikepoole82104
                    Eclipse list 14” blades in 6,10,14 tpi and 0.050” amd0.062” thickness. They are often on eBay and sometimes cheap.
                    ( they actually list 350mm but I wouldn’t argue about the difference)
                    Edited By Mike Poole on 14/06/2019 12:55:42
                    #414567
                    Graham Porcas
                      @grahamporcas42677
                      You are right but I object to the prices usually asked for 14" blades on eBay, they never seem to be cheap when I look!
                      16" blades are much cheaper and more readily available, so perhaps I should try shortening them?
                      Graham
