If that's a live steam engine …
Hi Michael,
Yes it is, but it's nothing special, apart from being small (4mm/ft).
A simple pot boiler with an oscillating cylinder, 3mm bore x 4mm stroke. The cylinder is hidden behind the side screens and the visible cylinder block is only an empty shell.
Firing is by butane gas using a trough burner in the firebox and belly tanks. Run on one filling is about 2 minutes.
It was intended to run with the "Faller" magnetic road system (the guide skate is just to the right of the pound coin) but really it runs too fast to be authentic. I am trying to draw up a Sentinel lorry using the same type of engine, which should look better running at speed.
My mk 1 eyeballs are not really up to marking out such small stuff, which is why I need my CNC mill running again!
Bitzer
Edited By Bitzer on 23/08/2018 13:53:28
