Neil Wyatt if that's the case then the PCB's should be fully repairable. RS should stock the components and the operation parameters will be done with PCB components rather than programing. I was fully expecting a programmed chip to be on there at some point that was a known point of failure.
Either way I'll have a good browse of the PCB's and the after market ones to see what modifications have been made. And if those mods can be done to an original board. It might be something ridiculous like the addition of a few TVS diodes to clean up any current spikes from the motor getting back to the boards and frying FETS. Or Using a big FET to act like a motor switch relay. Either way that style of low level electronics is well within my reach.
I'm also going to look into the delta inverter/ac motor setup warco are selling to see if it's worth the extra. The lower speed and increased torque might be beneficial, but only if it's a quality motor with good magnets.
I'll also have a look for the Coventry Model Engineers. I'll get in touch before I buy anything as it might be the case that a local has a machine available that would suit. I don't really want a short machine and don't have the space for a full bed so I think the chances of finding something in the sweet spot second hand is going to be hard, Especially with PCF. I'm also wanting the option for a bolt on mill and I know the Weiss has that as standard on most models.
I'm not in a great rush to buy, I'd rather have done 2-3 months reading reviews and knowing the short comings of the model I pick, rather than going in blind and then realising I've made a mistake. I'm also Northern (come from York), So parting with cash is a religious experience!
Edited By Blake Nesbitt on 14/04/2017 23:05:41
