Hi all….. Rod from Cinderford, Gloucestershire, and just getting back into ME and lathe work after a break of around 30 years
I was recently digging around in a dusty drawer and found this little oscillator which I made goodness how many years ago…..
I can't remember whose castings were used. It sort of looks like a Stuart, but I'm not at all sure it is, and at the tender age of 71 I can't remember…. but it set me off again.
I bought myself a new Warco WM240 lathe (with those new fangled millimetre measurements) and have spent the last couple of weeks re-learning how to use it, and making a few tools and accessories ( and buying some), and now I am (sort of) ready to have a go at making things again. On the cards are a Stuart Twin Oscillator, followed by a Stuart S50.
I am reading just about every thread on here learning all over again.
Rod, I,v got a couple of ideas about your motor, (1) if the motor is 2 1/2" high with a 1" flywheel, and has a bore of 7/16", and a stroke of 7/16" it, the ST Oscillator. (2) similar size, castings from the late 1920s/ early 1930s, and a bore of 1/2", and stroke of 3/4" it is the vertical oscillator version of the Progress motor. So it's probably number one.
John who worked for Nick Staniford sometimes, when I wasn't driving trains or playing around with narrowboats! You taught me how to solder etched brass kits using Coke as flux…I still do that to this day!
John.
Author
Please log in to reply to this topic. Registering is free and easy using the links on the menu at the top of this page.
