Hello from sunny Northumberland.
Home Forums Introduce Yourself – New members start here! Hello from sunny Northumberland.
  • #228727
    Alan Maughan
      @alanmaughan82992
      A nice sunny day here in Northumberland and a new workshop to kit out so life is good.
      Ive been out of engineering for around 15yrs after losing my workshop and all its contents due to a relationship breakdown. Now I've rented a new place, I have some money in the bank and things are starting over again.
      Sadly back then I had good gear and Im shocked at just how much prices seem to have risen for often very tired old stuff now. I bought myself an almost new Warco GH1330 after looking at far too many tired old Harrisons and Colchesters, so far Im quite impressed with the machine once I set it up properly.
      Ive also just picked up a clean Myford VMF but as yet I need to source tooling so can't say what this machine performs like, I expect it will be good enough for my needs though.
      Its quite a daunting task when you look at everything I used to have and what it would cost to replace it all but Ive got to start somewhere so here I am
      Alan Maughan
        @alanmaughan82992
        #228735
        Involute Curve
          @involutecurve
          Good luck mate
          #228736
          MW
            @mw27036
            Im actually slightly envious of that lathe, welcome to MEW forums.
            Michael W
            #228738
            Anonymous
              Alan: Welcome to the forum. It's sunny down south today too! I'm a regular visitor to Northumberland around Wooler. I fly with the Borders gliding club at Milfield from whence we can hill soar Cheviot.
              #228739
              mechman48
                @mechman48
                Welcome Alan,
                I can relate with you on the relationship score, many moons ago, like you, picked my self up & started again.
                George
                #228749
                Gray62
                  @gray62
                  Welcome Alan,
                  Good choice of lathe, I've had a GH1330 for several years now, it's been good to me so far. I changed the motor recently for a 3 phase/inverter setup, a worthwhile conversion in my opinion.
                  I've also added a mod to the tailstock to allow lever feed original concept was designed by John Stevenson of this forum), I've found this a very useful addition. There are some pictures of this in my albums
                  One thing I did find was that although Warco state the spindle bore is 38mm, there was a constriction part way down the bore which meant I could only get about 36mm bar right through. I line bored the spindle with a a specially made boring bar to overcome this.
                  I'm working on a couple of other mods for the lathe, to add a spindle drive clutch and a modification to the forward/reverse mechanism to allow single point pickup/reverse for screwcutting when the half nuts have to be left engaged, this will also allow feed to be stopped and reversed without first powering off.
                  #228781
                    Welcome to the forum, Alan.
                    Russell Eberhardt
                      @russelleberhardt48058
                      Bonjour et bienvenu from the not so sunny South of France today.
                      Russell;
                      #228837
                      Alan Maughan
                        @alanmaughan82992
                        Thanks for the warm welcome guys.
