Chris,
Have had a quick look at my ancient Warco bandsaw, of the same generic type, which have a 3-speed pulley set.
The motor is 1/3 HP 1420 rpm, so yours sounds OK.
The 3-step pulleys measure, across the rim, as follows
motor pulley 47, 54, 66 mm across outside diameter. Largest nearest to motor casing.
drive pulley corresponding sizes 94, 74, 54 mm across outside diameter
The width across the 3 pulleys is 48 mm
The pulleys are cast iron and a bit rough (only machined in the 'V' ) so measurements are to nearest mm.
Edited By Robbo on 06/02/2016 11:25:23
