Posted by wotsit on 29/05/2012 21:13:45:
David G is not completely correct – as I and other users have found out, the link simply takes us to the 'Introducing the …' page. Clicking on the URL from there produces a 'Website not available' page, and various reasons why. (as described at length above) It also does this from my PC (Ubuntu). Your amended link above does exactly the same thing.
(Geez I wish this editor would let you insert inline comments)
(Edit: come to think of it it probably does you are prepared to quote-and-edit multiple times)
Fair enough on that first link but I don't see why you would expect to get anything sensible from the onward link from there with a PC. It's obviously designed and encoded for tablets and if you try with anything else you're detected as "not tablet" and shunted off to a "page unavailable" screen. No surprise there.
More problematic is the fact that, as you say, it won't work for Android 2 (2.6.32.9 in my case). I tried it and got the same result as you. It would appear not to be set to recognise that Android flavour and therefore detects it as "not tablet" with the expected result. It should either (preferably) be made to work for all releases of Android or the exceptions should be clearly stated to avoid wasting people's time.
I know it works (or did some weeks ago) for iPad (2) because I tried that on mine.
(First time I've used the Android in ages …. I'm with David C on that one
Edited By Sid Herbage on 29/05/2012 22:33:15
