Posted by Eric Cox on 11/07/2013 08:53:24:
The simple mill engine ME 4460 p115. The bill of material gives the size of the base MP1 as16mm sq x 50mm, the same as the valve chest CP3.
Also the photo shows the cross head secured by brass dome nuts but they are not listed in the fastenings p116.
Just a minute, this article is by the Technical Assistant, who's checking the checker ? or in this case, not.
Edited By Eric Cox on 11/07/2013 08:55:10
Hi Chaps back from the hols bin up in the artic circle looks like i was missing summer in the UK. The part MP1 would be better described as the cylinder base as Jason suggested, I'm planning to design other engine using the same cylinder parts but these wont need the base. As for the dome nuts, the smallest cemercial dome nuts i could find were M3 and i think they would be a tad over size so on the bill of materials I just specified M2.5 nuts, but i fancied using dome nuts so just made my own they are straight forward to do, but if any one wants to know how to do them i can aad some info her. You don't have to folow my plans exact if you want to add some wistles and bows you can do, you will see that i fancied up the engine base some what but didn't show this in the drawing that I've kept simplified. Hope this helps and thanks for you're interest Stew
Edited By Stewart Hart on 13/07/2013 10:35:43
