Warco sent some bod around to fix it. If he had told me they gave him the wrong part I could have saved him 5 hours by fitting it myself, the whole thing was coming apart anyway…
I am well acquainted with Warco brass feed nuts, 0.2mm of backlash means you either climb mill or break your tools when it plays catch up. New screws have already arrived.
It had a glass DRO across the back of the bed and a horizontal spindle nose to rip it off the moment you got careless. There is room to fit the DRO under the bed so that is where it is going.
With a vast array of contactors they managed to connect 2 motors to one VFD, with reverse and rev counters. Everything started out at a nice safe 24Vac but then they added a 240V DRO display and a power feed which drapes a 3 core PVC flex across the front of the machine, all 3 wires connected to mains live.
The machine has enormous potential. I am not complaining, I am having lots of fun fixing it up. Fitting Bellville washers to ball screws for zero back lash, plumbing in an oil pump, CNC'ing it, I will soon get to see the gears that wind the knee up and down. They couldn't get back lash in that nut due to the force of gravity so they put extra slop on the bevel gears to simulate it, hoping for a keyway, expecting a taper pin.
Anyway, no insurmountable problems yet, it is going to be wonderful when I finish it
