I have had nightmares about this!
There is little information out there that is definitive but it appears the majority of mini-lathes have 1.5mm pitch leadscrews but some have 2mm pitch.
But… when I wrote the article I produced tables for both metric pitches, so I've uploaded them to a pdf (with the tables in handy print out and laminate style!) linked to by the article here:
I hope that helps,
P.S. an odd situation – a 1.5mm/2.0mm metric leadscrew fitted with a handwheel with a 60/80 division graduated collar will give you better 'thou' accuracy than anything you can fit to an imperial leadscrew (e.g. the 64 division wheel I have fitted to my 16 tpi leadscrew)..
