Photograph of Wolf Cub drill wanted
Home Forums Model Engineer & Workshop Photograph of Wolf Cub drill wanted
Viewing 25 posts - 1 through 25 (of 34 total)
  • #38171
    David Clark 13
      @davidclark13
      David Clark 13
        @davidclark13
        Hi There
        I need a decent photograph of a Wolf Cub drill. Just the drill on its own with no accessories.
        It must be a photo taken by you rather than copied from the Internet.
        The article supplied has a photo copied from the Internet which is not allowed.
        regards David
        #114257
        The Merry Miller
          @themerrymiller
          Two weeks ago David I could have given you one (pardon the expression).
          I won mine in a raffle at work in 1954 when I was an apprentice and it hadn't been used for over 50 years. It was set up on the authentic saw table and that was never used either.
          I eventually dismantled mine to gain access to the chuck and gears.
          None of the above helps you I know but it's just nice to resurrect old memories.
          Len. P.
          #114260
          Sub Mandrel
            @submandrel
            Would a scan from a very old advert do?
            Keith Long
              @keithlong89920
              Hi David
              Pretty sure that we've got an old, battered and decreit specimen of one of these lurking at the back of the tool cupboard at the local (amateur) theatre. I'll be working there on Friday and can photograph it then for you if that's early enough? It probably won't look too pretty but at least it was functional the last time I tried it about 2 years ago.
              It almost certainly wouldn't pass any safety inspections either with the mains cord.
              Keith
              #114269
              jason udall
                @jasonudall57142
                .Sorry .. mis read the title…
                in the UK the Wolf Cubs have being called The Cubs ( droping the Wolf bit) since about 1976 ( along with the caps from uniform).. but the best place to look for archive or other activity photos would be through http://WWW.scoutbase.co.uk… they will also be able to advise on the use of images of young people..
                regards Jason
                Edited By jason udall on 12/03/2013 13:17:46
                #114273
                David Clark 13
                  @davidclark13
                  Hi Keith
                  No desperate hurry.
                  regards david
                  #114275
                  Keith Long
                    @keithlong89920
                    OK David, I'll get the pictures done this week and be in touch.
                    Fortunately it's a production week at the theatre so not much work for scene builders to do on Friday – unlike the last 7 weeks!
                    Keith
                    #114309
                    Robert Dodds
                      @robertdodds43397
                      David,
                      Is this the model you're looking for?
                      Bought about 1950 to construct an angle iron and asbestos sheet garage for Dad's first post war car! Still a good runner (drill not the car) with an allen key locking 1/4" chuck, it usually has a flap wheel fitted and is at the ready.
                      Bob D
                      #114475
                      Sub Mandrel
                        @submandrel
                        To paraphrase Crocodile Dundee:
                        "You call that a drill? This is a drill!"
                        Wolf Drill
                        Ian S C
                          @iansc
                          If Bobs photo is OK, I'll not bother, but I can get a photo or two of a well warn one that was used by l electrition for ove 50 years, its in the local museum, in its as used condition.
                          Don't know if its a Wolf, but I think the museum has a larger drill than yours. Ian S C
                          #114508
                          Keith Long
                            @keithlong89920
                            Well I photographed the drill today as promised and then found out it wasn't a Wolf of any descrition – It's an ancient Bridges model!
                            So after all that I can't help anyway!!
                            Sorry if I'd raised anyones hopes too high, best use Bob D's pictures if you can.
                            Keith
                            #114516
                              Posted by Robert Dodds on 12/03/2013 20:59:26:
                              … with an allen key locking 1/4" chuck …
                              Bob D
                              Bob,
                              Those are useful little chucks: I have a similar one [but the sleeve is Aluminium Alloy] mounted on a handle … it's great for holding small components for filing, etc.
                              Nicholas Farr
                                @nicholasfarr14254
                                Hi, the advert shown below from a local iornmongers Autumn 1958 catalogue (sadly no longer trading) is of a Wolf Cub which should confirm Bob D photos
                                Looks a bargain at the price, but to put it in prospective, this was almost as much as my farther earned in a basic week at that time.
                                Regards Nick.
                                #114574
                                Sub Mandrel
                                  @submandrel
                                  I obviously ought to be more creative with my drill: **LINK**
                                  $1200!!!
                                  Robert Dodds
                                    @robertdodds43397
                                    Neil,
                                    What do they mean when they say "converted to electric"? I thought they started life as electric drills.
                                    I think I prefer the electric cornet, although I don't think it will play mp3s!
                                    /**LINK**
                                    Bob D
                                    #114584
                                    Ian S C
                                      @iansc
                                      P***y, rip off merchants, hope they stay in Auckland if they don't go home. Ian S C
                                      #114590
                                      Nigel Rice
                                        @nigelrice73086
                                        This post has awakened a few memories! A Wolf Cub was my first "machine" tool, purchased for £4.19.6 with money earnt working as a temporary postman over Christmas of 1947. Parts were later added to turn it into a wood turning lathe and drill press. I was so proud!
                                        #114599
                                        Sub Mandrel
                                          @submandrel
                                          My Dad has some Black and Decker accessories allowing their pistol drills to be used as a lathe, very similar to the Wolf Cub set. He uses it for wood turning too large for his unimat, such as the gun barrels on his Warspite.
                                          John Wyatt's 1:48 model of HMS Warspite at Knap Lake, Barry
                                          Edited By Stub Mandrel on 17/03/2013 10:04:52
                                          #115012
                                          Falco
                                            @falco
                                            Hi David,
                                            Hope these are of some help.
                                            Drill pic 2
                                            Drill pic 1
                                            Drill pic 3
                                            #115025
                                            Springbok
                                              @springbok
                                              Hi Stub
                                              Looks a fantastic model
                                              Bob
                                              #115156
                                              Ian S C
                                                @iansc
                                                My dad used a Black & Decker drill and Lathe attachment for making wooden toys, but anything over an inch or so in dia was a bit too much, and it was hard on armatures in the drill. Gave the B&D lathe away, but I think there is one for a Wolf Cub somewhere in the workshop, unless I'v put it in one of the museums around here.
                                                Like the ship, how's it powered. Ian S C
                                                #115246
                                                David Clark 13
                                                  @davidclark13
                                                  Hi Robert Dodds
                                                  I have used the top photo in your post.
                                                  Contact me at david.clark@myhobbystore.com to arrange payment.
                                                  regards David
                                                  #120745
                                                  ben dover 1
                                                    @bendover1
                                                    My own photos. drill itself is not working. blows the house fuse
                                                    #137378
                                                    Mark Stevens 2
                                                      @markstevens2
                                                      Not wanting to Hijack the thread, I don't have the drill but I do have this :
                                                      I was given this over 20 years ago and have never used it. Any pointers on how to set it up would be very much appreciated.
                                                      Mark
