Hi Alan, and the rest of the Guys
I am coming around to the idea that it not the tool per se, but the operator. Why else would some users suggest using a stiff tool, whilst others are advocates of sprung ones. Whilst yet others say rear is the only way to go, despite the fact that others have no problem in the front. (I know sprung tools have not had much mention here but they were demonstrated, with great success, at Harrogate a few years ago.) Could it be, rather like faith healing, that if you believe it will work than it does.
Having said the above does not mean that any old bit of tooling is going to work as well as a properly thought out bit of kit.
As with all self taught activities the only way to find the best way of doing something is to try every technique you can and decide for yourself.
chriStephens
PS the vertical tool, mentioned at the start of this topic, does sound like it has merit. Certainly if a dig in happens, and something has to give, the blade breaking is less likely to be the outcome. Of course a dig in is less likely if the operator has the "knack" or can hear when trouble is going to happen.
