7/16″ BSP Tap
7/16″ BSP Tap
Home Forums Model Engineers’ Workshop. 7/16″ BSP Tap
  • #87682
    John Stevenson 1
      @johnstevenson1
      Other day Malc the scrappie called in for a cuppa and to see if he could borrow a 7/16" BSP die.
      I said I'd never heard of one, didn't mean to say there wasn't one, just I'd not heard of one.
      He insisted he'd got the taps but no die.
      So looked in various books, World screw threads, MH, Machinery screw threads book but all list 1/4", 3/8" then 1/2"
      Even the specialised tap and die people don't list one.?
      Anyway he popped in again to day with a tap and sure enough it's clearly stamped 7/16" BSP x 19 threads and it looks to be about the right size, looks close to a 3/4" UNF as a guide size.
      Even took a picture
      Anyone else heard or seen of a 7/16" BSP ??
      John S.
      Edited By John Stevenson on 20/03/2012 22:36:03
      John Stevenson 1
        @johnstevenson1
        #87684
        Ian P
          @ianp
          Parallel or Taper?
          Ian
          #87685
          DMB
            @dmb
            Not 1st April yet.
            John Stevenson 1
              @johnstevenson1
              No, no joke, dead serious.
              It was parallel but I even looked under tapered charts and nothing.
              I have plenty of old engineering books, in fact I collect them and have about 7 that have nothing but screw threads in them. One list threads that obscure it even lists Manchester Plumbers Thread for copper pipe, only used by plumbers in the manchester area.
              Also it lists the original Whitworth pipe threads which are very slightly different from the modern ones but again no 7/16"
              John S.
              #87688
              Anonymous
                Only reference I can find is for petcocks on old British motorcycles; like this:
                http://www.steadfastcycles.com/cart/index.php?main_page=product_info&cPath=171_176&products_id=3917
                Be about right; use an obscure thread nobody else uses, so the punter has to come to you for spares.
                #87691
                  Tracy's have 7/16 x 19 taps and dies listed under specials.
                  J
                  #87693
                  The Merry Miller
                    @themerrymiller
                    Our spammers are up nice and early this morning!!!
                    Len.
                    #87694
                    John Stevenson 1
                      @johnstevenson1
                      Andrew,
                      Interesting link but for experiance all the fuel fittings I have come across are 1/4" pipe. This 7/16" pipe thread is about 3/4 to 7/8" outside diameter which is large for a motorcycle fuel fitting.
                      Jason,
                      The tracy taps are 7/16" OD pipe is different in that the size is the hole down the middle of the pipe but I'm probably telling you how to suck eggs.
                      John S.
                      #87695
                      peter walton 1
                        @peterwalton1
                        JasonB, bsp is no where near to normal 7/16 much nearer to 7/8.
                        Peter
                        #87804
                        Ian S C
                          @iansc
                          7/16" Is near to 1/4"BSP (but not quite), the thread number is the same. I have'nt been able to confirm it yet, but I seem to remember it as a gas thread, and I think the pipe size is the external size unlike water pipe, I'll have another dig and see what I find. Ian S C
                          #87806
                            Ian you are making the same mistake that I did. JS's tap is about 3/4 dia so that would be about right for a 7/16 ID pipe with 1/8" wall thickness.
                            J
                            #87807
                            lily brown 1
                              @lilybrown1
                              I find a useful post about 7/16" BSP
                              are you interested in having a look?
                              come here
                              #87820
                              Ian S C
                                @iansc
                                J, oops, so it is very fine thread is'nt it, normal wouldbe about 11TPI. Ian S C
                                #87821
                                  Well about right for BSP as 1/4" & 3/8" also use the 19tpi before it changes to 14 for 1/2"
