Printing from the archives
Home Forums Model Engineer & Workshop Printing from the archives
  • #63949
    Brynjar Berg
      @brynjarberg36021
      The program used for accessing the archives has also a function that would let you download a .pdf version of the page. The function should be accessible on the Navigation Menu, as described in the help-screen:
      “From this menu, you can navigate between pages, open search or index window, look for help, download PDF for print, etc.”
      These options does not show on my computer and I’m wondering if they are disabled or if I’m doing something wrong.
      It would be very practical to be able to send all pages of an article to be printed to a PDF-file, in order to format the print properly (double-sided, booklet, or whatever.)
      (Yes, I can print each page separately, so it is mostly a question of saving paper)
      Best regards,
      Brynjar Berg
      Brynjar Berg
        @brynjarberg36021
        #63958
        Gray62
          @gray62
          Since the change in the magazine viewer, the ability to print multiple pages has been removed (despite the fact that the underlying application has this ability)
          There is an application called PDF creator which acts as a printer device and allows you to add multiple pages to a queue and then combine them into one PDF document.
          Download from here http://www.pdfforge.org/
          #63959
          Brynjar Berg
            @brynjarberg36021
            Thanks for the information. Seems a shame to have to do it this round-about way, but it will work I Guess.
            Brynjar
