Posted by Ian P on 11/12/2017 21:37:35:
Michael
How does burnishing change the shape of a part?
I can see that on a microscopic surface level it might change the size of a part but curious how it could reverse the splayed tips.
Ian P
Ian,
I closed with the comment: "… I hope that makes sense."
Clearly it did to Bob, but not to you.
When I used the term 'burnishing' [in quotes], I meant the process of using a burnisher to gently work the tips back to a good shape … The 'suitably sized rod' provides supprt and acts as a former.
It's rather like the 'rubbing' process that jewellers use to set cabochon stones, or lens-makers use to mount elements … but linear.
Does it make sense now ?
Edited By Michael Gilligan on 11/12/2017 21:49:50
Edited to correct spelling of cabochon
Edited By Michael Gilligan on 11/12/2017 21:59:02
