Martin Evans Royal Engineer
Home Forums Model Engineer. Martin Evans Royal Engineer
  • #319704
    Steamgeek
      @steamgeek
      Did Martin Evans serialize the building of Royal Engineer in ME ?
      If he did any idea of when it was published ?
      Steamgeek
        @steamgeek
        #319727
        Clive Brown 1
          @clivebrown1
          As no one else has answered:- to the best of my recall, ME described RE in a series of articles which also included Royal Scot, Fury and (?) Leander as variations.
          Reeves list most or all of the castings as applying to all 4 designs.
          Don't remember the date, but I'd guess mid '80's.
          Hope that helps.
          Edited By Clive Brown 1 on 02/10/2017 19:05:51
          #319730
          Thor 🇳🇴
            @thor
            Have you tried searching this ME index?
            A search for "Martin Evans Royal" gave amongst others; #3224, #3371, #3374, #3380, #3382, #3384, #3389…. These are probably for Royal Scot, Royal Engineer #3516, #3519…
            I don't know if this may be of help?
            Thor
            Edited By Thor on 02/10/2017 19:19:04
            #319734
            alan ord 2
              @alanord2
              In Blackgates Engineering catalogue it says that two versions of Royal Scott 4-6-0 Loco and Tender 5" by Martin Evans were described in ME volumes 140 – 141
              Alan.
              #319735
              Robbo
                @robbo
                Royal Engineer articles were mixed in with "Fury", which was a high pressure compound, Engineer was a standard 3-cyl Royal Scot.
                So if you look in an index you need to cover both.
                But started about Oct 1974 start looking at issue 3499, 3500 – ish
                #319796
                Steamgeek
                  @steamgeek
                  Thanks all for the info, especially the link to the ME index
                Home Forums Model Engineer. Topics
