My first ship in 1964 had a Doxford engine, but I thought the company went burst in the 70's, certainly by the 80's.
I am amazed that a broken con-rod did so little damage that they could make the engine run with the just broken con-rod and attached bits removed.
Doxford engines – opposed piston 2strokes – had spherical main bearings. Taking crankshaft deflections was a nightmare as the readings were all over the shop!
I believe an old Port Line ship built in 1955 is, or was until recently, still going having been converted into a cruise ship – where they get the Doxford spares from is any bodies guess! You can google m.v Port Sydney and read all about it!
Having said that, it was a very resourceful voyage that Clive's son had, if a bit traumatic! Wouldn't have liked a cargo of granite – sailed on an ore carrier once, never again, reckoned if we hit trouble it would have none of the floating characteristics considered desirable.
i have sailed on a ship where we had two units disabled, on a V14 medium speed engine, but all the bits were still going round and round and up and down, just the fuel pumps lifted on the two units, one unit was off to balance the other, but never on an in-line engine with bits missing.
I am still amazed at the story, when the con-rod snapped that would have allowed the cross-head complete with piston and piston rod – a not insignificant weight of metal – to drop down onto the bottom end, and what damage did the broken co-rod with the piston etc dropped down on it do before they managed to stop the job? Glad not to have been on that ship!
Chris
Edited By ChrisH on 20/03/2014 20:18:50
Edited By ChrisH on 20/03/2014 20:21:18
