Sikaflex for sure it also sticks very well if the surface is clean, contact the local supplier. Never silicone, it is not nearly as durable, and forget expanding foam for detail work.
For a nice job mask both sides with tape. apply the Sikaflex to the slot then spray on a little soapy water (if needed) then smooth with a wet finger. finally remove the masking tape straight away while the Sikaflex is still wet. Finally! try not to improve and fiddle with it unless really necessary.
That's how the professional Caulkers do it.
Oh! Sikaflex is available in colours.
Edited By John McNamara on 12/07/2023 08:48:12
