Ideas on how to re-connect a broken thread in an alcohol thermometer
Home Forums The Tea Room Ideas on how to re-connect a broken thread in an alcohol thermometer
  • #618656
    Greensands
      @greensands
      I have a 0-50deg alcohol thread thermometer sold for use in aquariums which I have been using as an outdoors thermometer. Problem is that despite being in a fixed location mounted on a shed wall it has suddenly developed a broken thread and traditional methods of trying to reconnect the thread by means of flicking the device has not had the desired effect. Can anyone suggest any other tricks which might be worth trying? The break in the thread is typically 1/4" in length.
      Greensands
        @greensands
        #618659
        peak4
          @peak4
          The only ones I've had have a little expansion area at the very top, where the bore is a larger diameter.
          I've successfully heated up the bulb, such that the alcohol or mercury extends all the way up the tube, just into the expansion bit at the top.
          When the fluid cools, it pulls the whole lot down again.
          For obvious reasons, care is required so the contents don't expand too much and burst the glassware.
          Bill
          #618666
          Dave Halford
            @davehalford22513
            As Bill says, overheat and the bulb blows clear off.
            #618667
            Rod Renshaw
              @rodrenshaw28584
              +1 for the idea of overheating to the extent that the level goes up into a larger diameter part of the glass tube, and I also see the risks.
              I note that the OP's thermometer reads 0-50 degrees. If the thermometer is put in a freezer, in a vertical position, will the alcohol level drop into the bulb, and then expand in an unbroken column when the thermometer is returned to room temperature? Don't leave it in too long, you don't want the alcohol to freeze!
              Rod
              #618668
              Neil A
                @neila
                Freezing point of alcohol is -114.7 degrees Celsius. Most domestic freezers only go down to -18 or there about. I don't think you will have a problem there.
                I think I would try the freezer first, less danger.
                Richard Millington
                  @richardmillington63972
                  As above.
                  Last one I did was by over heating so the "bubble" went to the expansion area, (just dipped it in a hot kettle) easy to control – just take it out of the water to cool down.
